Aleksandar R.
Sponsor: RAAL 1995
The TI-1c is 8/4 Ohms interface and the default TI-1b is the 32/16 Ohms.It's a bit hard keeping up with all of the product changes. The site lists the 1b only right? Is the 1c a new version after?
Does anyone know if that's the version shipping by default now? I'm not too worried about differences between the two versions much, but having just placed an order, would prefer whatever is most recent/optimal from out of the gate.
The headphones require about 6W (at whatever impedance the amp is comfortable working with).
If your amp makes 6W at 32 Ohms or 16 Ohms, use the B version.
If your amp is a (up to) 6W tube amp that has 8/4 Ohms outputs, you will develop half the needed power (and the amp won't work optimally) if you use the B version at 16 Ohms, so in such cases, the C version is recommended, as that matches the load that amp expects to "see".
So, with two available interfaces, you can choose the loading for your amp of 4, 8, 16 and 32 Ohms.
Stay updated on RAAL 1995 at their sponsor profile on Head-Fi.
