eboleyn
The SR1a was designed in Serbia using the AHB2. However, this amp requires something warm in front of it if using it with the RAAL. My sold state CODA 07x (tubey) was not warm enough to tame the RAAL. While the Freya+ ($1000) does tame it. The 07x is a much better preamp, but I am talking about taming the beast here.
I think that's a "Your Mileage May Very" kind of comment.
Let me distinguish a term used when speaking about "neutral" DAC/amp/speakers. Often they can be called "harsh" or even "brutal" by some, but as I've explored the newer generations of extremely accurate neutral components, I'm fairly sure that this has been due to the lack of accuracy of these components, and in their attempts at neutrality they have a kind of noise which our human hearing system finds unpleasant. I will absolutely grant that people who prefer "pleasantly distorted/warm" sound can find a sufficiently accurate and neutral component as ... well, "bland" or "unexciting".
My personal listening and demoing to others of my DAC/amp/SR1a stacks with highly accurate modern DAC/amp combinations vs other extreme accuracy experiments says that the SR1a goes into that zone of high accuracy/neutrality unblemished by "harshness" and gives you exactly what you put into it.
There are 3 different DACs I use in that category of "completely accurate": Schiit Modius, Topping D30 Pro, and a Sabaj D5. All sound absolutely identical as far as myself or others I've demoed to can tell.
My favorite 2 stacks to drive SR1a after the DAC:
- Neutral:
- Amp - Purifi 1ET400A (class D) - Overkill if anything!
- Amp - Schiit Magnius - Needs hacked cable (to be clear, this is going into the SR1a speaker amp resistor box) but easy to do, works great as long as I don't need loud listening, sounds the same as the Purifi amp. Neutrality on the cheap!!
- "Pleasantly Distorted":
- Pre (optional for fun) - LTA Microzotl Pre, just using stock tubes
- Amp - Pass Labs XA30.8
