This means inserting a capacitor in series with the signal.Because I originally was planning to buy a HSA1a and because I already had a 2x100W amp I choosed the new interface box (with speaker switch) a year ago. Today I do not regret my choice since I upgraded for tube monoblocks and I would rather buy the silver cable than adding a JotR for about the same price. I plan to mod the interface box to tune the sound following my mood instead of using any EQ/DSP that could degrade sound quality.
https://www.head-fi.org/threads/raal-ribbon-headphones-srh1a.890603/post-14814740
Edit : I am wondering if we could do a High Pass Filter with this kind of mod, because I recently managed to pair the SR1a to a ML BF212 subwoofer with great success so I would like to relieve the ribbons from the load of the lows in order to improve even more the mids and highs (currently the bass from my SR1a is augmented but the headphones still play full range).
Open the connection of the signal wire and insert the cap in between, either by modding an RCA cable or at the interface box’s binding post.
Best done in front of the power amp, as the necessary cap is much smaller than on the power side.
This way the power amp would be relieved from the low frequencies too.
The size of the cap depends on the x-over frequency and the power amp’s input impedance:
E.g. for a 100 Hz high pass filter you need:
0.16 μF @ 10 kΩ (amp’s input impedance)
68 nF @ 22 kΩ
47 nF @ 33 kΩ
33 nF @ 47 kΩ
16 nF @ 100 kΩ
A 100 Hz highpass is 3 dB down @ 100 Hz, and 9 dB down @ 50 Hz
Best quality caps available are WIMA FKP3 (hard to get), 2nd best WIMA FKP2.
If you want to do it at the power side (between amp and interface box) the cap would be 270 μF for a highpass @ 100 Hz.
2 foil caps (one for each channel) of this value are too big in size to fit into the box, so you could mount them on the binding posts.
https://www.mundorf.com/audio/de/shop/Capacitors/?page=2&sort_by=sorting#
(Mundorf MCap Evo ME-270T3.250, scroll all down to the higher values)
You could use bipolar electrolytic paralleled with a smaller foil cap, but sound quality-wise this approach is questionable.
