I love the (bass heavy) AKG K-1000 on my RME ADI-2 Pro.I have tried these a few times, but each time I quickly developed a headache due to the pressure from the pads on my temples. I must be sensitive to that. As a result I could not really get into them. Does anyone else have a similar experience?
As I do not listen very loud in general I can use ADI-2's EQ to extend the bass down to 30Hz without running into distortion (shelving, +12dB, 58Hz, Q=0.8)
- and remove the peak at 2kHz (-5.5dB, 2.0kHz, Q=1.2).
I've angled the baffles by 20 degrees, so that there is a space of about 1cm to my ears.
The metal headband arcs I've carefully bent a bit outside, so that the little pads just fit tight enough to keep the K-1000 in place. This way it's very comfortable and I can wear it for hours, even on hot summer days.
For amplification: the AKG K-1000 loves a bit higher output impedance: 33 Ohms in line improves the sound, compared to ADI-2 Pro's native close to 0 Ohms.
I even have an OTL tube amp and a solid state amp, both specially designed for the K-1000, but the RME ADI-2 Pro's headphones out (with added resistor) drives them very, very well too.
I'll have to have a listen to the RAAL SR1a as soon as I can get one in hands, see if it meets or improves on the K-1000 qualities.
Currently there's non here around my place.
What kind of irritates me is the high number of reports about how amplifier, DAC and cable (what???!) dependent the sound quality of the SR1a seems to be.
Really bad with the "wrong" chain?!
The AKG K-1000 is not - it sounds great with whatever I drive it, as long as there is sufficient output power (~0.3W @ 120 Ohms, EQ'd - less without EQ).
