Raal Ribbon Headphones - SRH1A
post-15466761
Post #1,876 of 1,924
Thenewguy007
Here's the actual headphones with the cable that shipped with them. The interface box a bit different from the usual one in photos as well.
You can put some electrical tape around them as a temporary solution.
Reactions: cconnaker
post-15467177
Post #1,877 of 1,924
FLTWS
USA
USA
Edit: Thenewguy007 beat me too it.
post-15467445
Post #1,878 of 1,924
Pale Rider
NorCal, USA
NorCal, USA
Website
www.hammondraffetto.art
Any news on the HSA-1A amp? I love the JotR, but I have this unscientific suspicion that there is even more to unlock from the headphones.
post-15467686
Post #1,879 of 1,924
musicman59
Canton, MI
Canton, MI
Hi Guys - Thanks for all the information available in this thread. It has helped immensely.
I received my SR1a headphones today and quickly ran into an issue that I'd love some help with. Perhaps someone else has run into this same issue.
When I set the SR1a headphones down, the metal pieces on the end of the L+R cables, touch causing the pair of Schiit Vidar amps to go into protection mode. This only happens when music is playing of course. Seems like a poor design of the cables or something else is afoot.
Question: Has anyone else experienced this or does anyone have any thoughts about it?
Are you talking about the Black and Red housings? That's strange because those are normally made of non-conductive material.
post-15467705
Post #1,880 of 1,924
cconnaker
Minneapolis, MN, USA
Website
audiophilestyle.com
Yes. On mine they are both silver metal.
Today I switched all the electronics over to an isolation transformer with impeccable grounding and the issue is gone. Perhaps the outlet by my desk isn't grounded properly. Nonetheless, the fact that these are conductive is a strange one.
post-15468195
Post #1,881 of 1,924
earlinarizona
What size resistors are used in the adapter box. They look like 2 watts but someone out there probably knows for real.
post-15469483
Post #1,882 of 1,924
Kelowna
Member of the Trade: Mivera Audio
post-15469502
Post #1,883 of 1,924
Kelowna
Preliminary resistor testing is suggesting a phenomenal amount of performance potential is possible from standard speaker amplifiers when the very best resistors are used in the interface box. Yes resistor quality matters in this application as well. Even a single resistor in the signal path degrades performance. Let alone 72 of them. There's some new resistors on the market that are damn near as transparent as a straight wire. But the lead time is quite long, and only 1 factory in the world has the technology to produce them.
Reactions: Pale Rider
post-15469535
Post #1,885 of 1,924
Kelowna
Audio Note probably makes the best resistors being pure silver. They make up to 2 watt resistors.
https://www.audionote.co.uk/resistors
Price list. https://d1b89e86-9572-4311-9f80-60009b280608.filesusr.com/ugd/89c24f_6fd2291f0d7b4887b7e2a2351a3794ea.pdf
Depends if you shop by brand or actual quality. BTW they don’t make those resistors. They just rebrand them and up the price by 20-30x. That pricing level is required to attract attention from the audiophile community.
post-15469600
Post #1,886 of 1,924
Aleksandar R.
Member of the Trade: RAAL-requisite
Serbia
Serbia
It seems to be, but it's just odd that there's no insulation on the cables at the metal connectors to prevent this.
Hi Chris,
The connector shell is connected to ground lead (or negative lead).
It never occurred to me that the two connectors will touch and thus, trip the bridged amp protection.
Once the amp is bridged, the "ground" will become live, not at 0 potential any more, so unlike normally driven amps, you can't have the "ground" from two channels be connected.
I'd use a piece of heatshrink tube and tighten it over the connector shell, or wrap it with a tape.
Also, please be careful with two bridged Vidars, as that is way over the specified power handling of headsets and Interface. It should be fine, just take care.
post-15469630
Post #1,887 of 1,924
Aleksandar R.
Serbia
Serbia
I think the issue will remain, because of amps being bridged, depending on the signal symmetry between left-right channel and on volume.
To me, it is very common that 3.5mm jacks with metal shell, the shell is a GND.
For the specified power handling, bridging amps is not necessary, so I wasn't thinking much about issues with bridged amps, sorry about that.
Anyhow, insulate them as I don't think the issue is gone by using ins. transformers.
post-15469634
Post #1,888 of 1,924
Aleksandar R.
Serbia
Serbia
5WS, or 5 W small housing.
The resistor influence in sound is a discussions as old as hi-fi and I'm in the wrong camp to carry on discussing that.
post-15469639
Post #1,889 of 1,924
Aleksandar R.
Serbia
Serbia
I'll just say that paralleling is better that using one high-power and that I use wirewound, as I don't like MOX.
post-15469645
Post #1,890 of 1,924
cconnaker
Website
audiophilestyle.com
Thanks Aleksandar. The only reason I’m using two Vidars is so I can use the balanced interconnects between DAC and amp. I have some other amps on the way for review with the SR1a. Overall, fabulous product. Nothing like it.
Users Who Are Viewing This Thread (Users: 2, Guests: 5)
