Good to hear this sounds good, bad to hear Kali doesn't work with DAC in Master-mode,,, this info wasn't available at there site in the beginning,,,,,,,,,,,,
I almost received all the components needed to start my 8x DA-M1 project, just waiting for 16P-DIP sockets for mounting all the Omron relays.
Tomorrow I will start project. It probably will take 1 to 2 weeks to accomplish (I have summer vacation now)
I will use:
8x DA-M1 R2R modules
1x Ian's FIFO 2 reclocker
1x Ian's DualXO 2 board with NDK NZ2520SD clocks (can exchange in the future)
1x Ian's Isolatorboard between FIFO 2 and DualXO 2 board
1x Ian's RPI-Isolator board
1x RPI 2 or 3 (will test which one sounds best) with latest audiophile PicorePlayer version
2x Dibao DB1736 output transformers (improved version of Lundahl LL1527)
2x Valab Rhodium plated Tellurium Copper RCA's
** Will use SE for the moment, my Pre-amp is SE only.
8-UltraCap psu's 3.3V with a total of 64 ultracaps
4-Ultracap psu's 1.8V with a total of 24 ultracaps
1-Ultracap psu 5V for Ian's FIFO II reclocker with a total of 4 ultracaps
1-Ultracap psu 3.3V for Ian's DualXO board with a total of 8 ultracaps
1-Ultracap psu 5V for Ian's RpiIsolator with a total of 4 ultracaps
** I am planning to use a total of 104 UltraCaps, but could be that I need more for a longer runtime. I prefer a runtime of AT LEAST 5 minutes for one UltraCap load **
** Since nobody did ANY measurements and calculations on drawn amperage from DA-M1 modules, I need to test and calculate all myself during the build **
** For future purpose I will share the measurements for all other interested diy-guys **
48x Omron G5V-2-12VDC relays
48x DIP16 precision IC sockets for mounting Omron Relays
1x DC-DC converter CV/CC at 3.3V
1x DC-DC converter CV/CC at 1.8V
1x DC-DC converter CV/CC at 5V
1x DC-DC converter CV/CC at 12V
1x Timer-relay-board
1x 19V-DC-9.6A adapter
And, of course lots of pcb's, wiring and connection materials, wooden panels, copper tape and a full aluminium enclosure.
Project will be based on RPI2/3 with AudioPhile version of PicorePlayer, which connects to LMS 7.9 server.
Final product will be an Ultra-High-End Network streamer which, in the future, will be expanded with several other input formats, such as SPDIF and I2S so it can act as a standalone DAC.
RPI2/3 has an Isolator board (HAT) on top (from Ian Canada) which outputs a galvanic isolated I2S and GND signal to the FIFO 2 reclocker.
FIFO 2 reclocker has an Isolator board connected to it on the output-side, and Isolator board has a DualXO 2 board connected to its output-side.
I2S signals from DualXO 2 board directly will feed the DA-M1 modules. Wiring will be as short as possible to keep jitter at a minimum.
All needed power will be provided by Ultracaps, except for RPI itself, this will be a low noise switching supply. Maybe this one will change into an Ultracap psu in a later stage.
Will keep you guys posted
Cheers!
Alex
