R2R DA M1 Ultracap powered build
Oct 17, 2017 at 9:57 PM Post #196 of 229
You use 1x 6.8uF only at HOT output and not at COLD ?
only one cap mean no output transformer,no dc servo ic,no j fets,nothing else,1-1 cap +and - .
Oct 18, 2017 at 3:56 AM Post #197 of 229
A bit like a traditional TDA1543 application, then...
Oct 18, 2017 at 3:57 AM Post #198 of 229
Does that mean you can leave the cap out altogether if you have a DC blocking cap on the input of your preamp?
Oct 18, 2017 at 4:56 AM Post #199 of 229
mean dac modules generated 0.5v gone.
Oct 18, 2017 at 5:31 AM Post #200 of 229
That depends on the value of your DC blocking cap on input preamp.
The DA-M1 modules generate rather high DC-offset about 0.5V
Nov 8, 2017 at 9:18 PM Post #201 of 229
System update....
Source:
Sparky Sbc upsampler 384khz play sd card(not stream!!!) 5v u cap psu - iso regen 7v u cap psu- Singxer f1 5v u cap psu- i2s
Dac1:
Detonator Reference 12 rail balanced u cap dac (No active or passive coupling or other stages ) dc offset removed by M10 preamp
Dac2:
Monyo : single ended 4 rail u cap dac.(4pcs lt 3042 reg, 2rail Dc in Analog,Digital) with decoupling capacitor
Amp1:
M 10 monorual mod. total 7 transformers-7 iso transformers
Amp2:
(Under the Develop)
Class D 2x 25w single ended ,direct connected to Monyo ,16v 100Farad u cap powered,volumio digital volume control,no relays,runtime 1hours /charge, charging time 5min without music stop.
(tested yesterday first, sound promising!!!!!)
Nov 10, 2017 at 9:06 AM Post #202 of 229
Nov 10, 2017 at 9:10 AM Post #203 of 229
the 20$ class D with ultracaps sound much detailed,blacker background than my modded m10
Nov 10, 2017 at 11:35 AM Post #205 of 229
I was quite some time absent because my father passed away Tuesday 31 Oct.
Will need some time to recover before I can concentrate on DIY audio again.
In the meantime it is good to see you are designing class-D with ucaps Balazs, keep us posted!
Best regards,
Alex
Nov 10, 2017 at 11:18 PM Post #206 of 229
yes,6x16v modules,bought this alredy a long time.only the class d module missed.really surprised the runtime with one charging,and the sound compared my monster size amp..overall new details come.
Now this is full ultracap chain ,without wall power , without noise,without unnecessary active or passive components,stages.
Nov 11, 2017 at 3:13 AM Post #207 of 229
Nov 16, 2017 at 7:10 AM Post #208 of 229
Interesting. Can you imagine how it would sound with a good sounding class-d chipset instead of the one you used, like ICEpower 300A1
Nov 18, 2017 at 1:50 AM Post #209 of 229
yeah,this chipset sound class d flavuor.Cant listen long time.
Dec 8, 2017 at 12:36 AM Post #210 of 229
Noticeable upgrade,between isolator transformer-power amp transformer.Power wire reduced 1.2m vs. 30cm.Better mid,soundstage accuracy.More real,without masking
