coinmaster
Unless the load draws a constant current in which case the supply will perform perfectly anyway, you are not going to get pure DC out of something that doesn't have 0 output impedance. I don't think you know what DC means. A regulator will give purer DC then any amount of caps will unless you have crazy amounts of them in series/parallel to match the impedance and voltage upkeep capabilities of a decent regulator, not to mention the capacitive reactance of the capacitors will be an issue (or a benefit) if you don't parallel enough of them as well. Also you are not going to be able to hear microvolts worth of noise, the noise argument is silly.
It's not wise to spread unproven opinion as fact, especially when you continue to prove you lack an understanding of basic analog theory.
Okay now I'm out
Okay now I'm out
