@Owludio i translated chinese review with google... sorry for bad translation i hope you can understand
https://www.spill.hk/headphones/SPEAR-Labs-ASL-45-review/
SPEAR Labs ASL 4.5
Readers who play with headphones are no strangers to the name Dale Lott. He was the founder of Aurisonics, former head of Fender headset department and chief designer, and is now the founder and chief designer of SPEAR Labs. The products he developed in different periods have all achieved good reputation in the market. Dale Lott is one of the leaders in the development of hybrid unit headphones. The most famous work is of course the Aurisonics era ASG 2.5. The newly launched ASL 4.5 this time is a tribute to the classic AGS 2.5 and matched with SPEAR Labs' own The unit and technology developed are aimed at redefining the sound quality standard of ring-iron headphones.
Headphone design
New special 14mm dynamic unit
The ASG 2.5 in-ear headphones launched by Aurisonics at that time used a 14.2mm moving coil with two moving iron designs. Its moving coil unit is so large that it is indeed rare. In order to continue the charm of the large moving coil, Dale specially made a 14mm SHOCKWAVE moving coil unit for ASL 4.5, with a diaphragm thickness of 1.1mm. Together with the N52 neodymium magnet, it is also only 3mm thick. The newly developed Hybrid-Acoustically-Balanced Universal (HABU) universal hybrid balanced acoustic technology has also been added to ASL 4.5. The diaphragm is thinner but extends the stroke of the unit. The advantage is that the low frequency has a better potential to provide a powerful and full bass performance. Like ASG 2.5, continue to use the crossover design, through the specially designed frequency band unit and natural crossover point method, reduce the energy loss caused by the crossover and the impact on the sound coherence.
Crystalline resin to make the shell
As for the earphone shell, the newly developed crystalline resin is used. This unique formula can greatly reduce any yellowing problems. Although it is different from the brand's previous metal materials, it uses layered production technology, using the very popular Thunder Gray in the automotive industry as the main color, and the recessed SPEAR Labs logo is even more hand-painted. Finally, Class VI ultraviolet rays are used to irradiate the shell to improve the purity of the crystal and protect the finish.
The back shell is made of transparent materials, and the moving coil and moving iron unit inside can be clearly seen.
Thunder Gray is chosen as the main color, and the SPEAR Labs logo is even more hand-painted.
Sense of wearing
There are more units, no increase in volume
As ASL 4.5 uses the newly developed ultra-thin moving coil unit, even with 4 moving iron units, the volume of the headset is not significantly increased compared to ASG 2.5; plus the resin material is very light and very close to the ear and stable after wearing , Relaxed and unburdened. In terms of earplugs, with nFORM XTR patented ear pads, it is slightly better than ordinary ear pads in terms of sound insulation and comfort, and its durability is better than ordinary ear pads. ASL 4.5 is of interchangeable cable design, but this time I did not use Pentaconn Ear to change the cable plug. Instead, it uses a more traditional CM 2pin interface. It comes standard with a newly designed silver-plated copper earphone cable. The cable body is quite soft. When the earphone cable swings At this time, there is no auscultation effect.
Wear it around the ears, with rubber sleeves on the ear hooks.
Use the more traditional CM 2pin switch interface.
The machine is equipped with nFORM XTR patented ear pads.
A silver-plated copper headphone cable is standard.
Sound quality performance
Low frequency and loose without fat and swelling
ASL 4.5 uses a large-diameter moving coil unit to process the low-frequency part. When it is turned on, the low-frequency volume is rich, but its tuning is not just a pursuit of low-frequency volume. It can create a three-dimensional feeling and a spatial atmosphere, and the potential at low frequencies is also very ideal. . In terms of vocal hearing, it is not overwhelmed by the low frequency at all. Instead, it is surrounded by a low frequency, which is very rich, and the rhyme can still maintain a fairly good line level. Although there are many large dynamic headphones on the market, the most rare thing is that the low frequency can achieve a sense of volume, looseness and swelling at the same time, and the three-frequency connection is quite natural, and the analytical power is good. This is ASL. The unique charm of 4.5.
A&futura SE180 connected to Astell&Kern for trial listening, the low frequency volume is rich, the human voice is very rich, and the three-frequency connection is quite natural.
Summarize
Beat the old works!
ASL 4.5 is a product launched at the same time as the Triton Infinity CM earphones reviewed earlier, but it takes a completely different route in terms of sound tuning. The sound of Triton Infinity is not easy to import, but ASL 4.5 is easy to fall in love with. While the low frequency dive is deep and has a lot of volume, it will not cover up the clarity of other frequency bands, but can highlight a strong sense of rhythm. ASL 4.5 is not limited to listening to a certain type of music, it is fully in line with the general omnivorous taste. The author also borrowed Dale’s old works ASG 2.5 and Harmony for auditioning. The new work ASL 4.5 is obviously over-class when compared to it. More details can be heard, the outline of the sound is clearer, and the three-band stereo perception is improved even more. The most impressive.
At the same time, I borrowed the old ASG 2.5 and Harmony for comparison.
Specifications
ASL 4.5
earphone type: in-ear
unit: 14mm moving coil + moving iron × 4, no crossover design
Frequency response: 7Hz to 24kHz
sensitivity: 108dB/mW
impedance: 30Ω
wire: silver-plated copper wire, 3.5mm plug
price: $7,800
