Alright, I've dropped a few pics to illustrate what I'm about to write about.
First of all, sorry for the delay; this is the hardest IEM to figure out after Rose Miracle(that I'm yet to figure out, but that's another story...) Also, I'm treble sensitive and most of the time IEMs with resolving upper treble make percussion and other upper treble dependent instruments sound thin.
I don't think I'm qualified to review RX10 as it's a first single DD IEM of this class, so all I can offer is a subjective opinion that has to be taken with a caution.
My experience with single DD is limited to something like Fiio FD5 which IMO performs at the top tier level as well as RX10 does but also with a caveat.
So, RX10 has been my daily driver since my last post and should get more than 100 hours on it between listening from commute to commute throughout a work day and burn-in when I take it off(which also helps to avoid accumulation of condensate and dry IEM out. It didn't change much, I've noticed more change from switching to 8 core copper cable which added some body to cymbals and upper strings.
1. I value technical performance but accurate tonality I value more and this is where the first wow comes:
Starting with the lowest sub-bass through upper mids - it's absolute tonal perfection with timbrel realism only 2-nd to Audeze Euclid that is at the next level. Euclid though has virtually no bass dynamics.
RX10 is the opposite- one of the most dynamic and responsive drivers. 2nd WOW. In fact I prefer lower part of RX range to virtually any other IEM in my collection and that includes IMR Astra and Thie Monarch MK2!
2. Amount of bass goes like this: Fiio FH7, Monarch MK2, Fiio FD5, FH9,
Simphonio RX10, Shuoer EJ07M, MEST1, iBasso it07, IMR Astra, ISN EST50. last 3 is a basshead territory IMO.
3. Control of RX10 bass is one of the best: RX10, IMR Astra, Monarch MK2, Fiio FH7,9, FD5, iBasso it07(all are top tier and close call), then EJ07M(also not bad at all), & ISN EST50 -basshead party.
The top tier ones tend not to lose resolution during heavy bass lines.
RX10 bass is addictive. If I switch to any other IEM, even MEST & Monarch, - I start to miss it immediately. The only IEM that holds my attention is Fiio FH9 as its bass is flatter but comparable in quality(perhaps better, but too soon to tell as I haven't even burnt in that one yet).
Speaking of flatter: RX10 is anything but - so articulate, so tight, even when subterranean sub lines are dropped! RX10 bass is 3d like, similar to Fiio and IMR.
4. The tuning: as I mentioned, to my taste lower part is perfection. RX10 is #1 and there is no close 2nd.
Now is a controversial part - upper mids through treble: I perceive upper mids lacking a body but BEWARE, that I perceive some of that also on Sony ier-M9. I use M9 with aftermarket copper cable to mitigate it. Also with perfect source and recording that somehow stops being noticeable turning in pure clarity.
Stage is not the widest but imaging is excellent. In fact stage on M9 is much wider, and TBH M9 imaging is better due probably to clearer upper treble. Tonality wise RX10 is reminiscent of M9 as it has the same emphasis on upper treble. Bass of RX10 however is tuned better than M9 and it's not close(sorry M9 fans, just remember, I'm a freak
Also, both it07 and all Fiios have vastly larger stage. If you love bass, - it07 or ISN EST50 are both fantastic and to me - comparable.
So, I cannot safely recommend RX10 because of treble oddity. BTW, treble of EJ07M is my all-time favorite. If RX10 had that treble- it would be TOTL end game for me.
Nonetheless it's a keeper: I bought it for isolation and fit and as expected it fills my ear-conchas completely and heavy ceramic-like body + non-vented DD makes the most isolating (non-hearing-aid-compatible (Shure SE846)) IEM I have currently.
Also, beware of very wide dimensions, it's wider than Monarch MK2. It's shallow and wide, perfect for me but YMMW.
Listening was done through iBasso DX160 and Note20U+Paw S1 from Tidal & Amazon HD.
As you can see below, I have some molding silicone covering sharp edges. I'll replace it to permanent fix soon as this IEM isn't going anywhere...
I wish someone like
@Dsnuts got to review RX10. Thanks for treble filter suggestion for FH9,- you were right yet again, but that is for different thread...
Also thanks to
@Xinlisupreme for poking, I wouldn't be writing otherwise, as I'm still not sure...
