Prog Rock Man
- Jul 2, 2009
So far, no actual answers to the original question. I am adding that to the proof that cables do not make any difference.
Funny thread. I've been swapping interconnects in my seutp, so I know first hand the effects. I recently picked up a pair of ASI Livelines, and my jaw dropped to the ground when I first listened to them. They sound nothing like any other ICs I've ever heard.
Interestingly, they also double as a digital connect, and I replaced a Nuforce digital cable between my Chord dac and Off Ramp usb converter. Bits are bits, right? Well, no. The Chord dac has massive resolution, and for whatever reason, there was a lot of music/details/definition I wasn't hearing through the Nuforce cable. Nevermind that the ASI cable is more musical and organic sounding.
I can't explain, and it's frustrating when you reach a certain level where every little change makes a difference. There are even users/designers reporting differences through computer playback with different brand hard drives & bit for bit perfect rips sounding different when ripped from different brand CD-ROM drives.
DBT-Free Forum.
Nope, just unsighted (blind) tests of any sort. No reference to the aforementioned double blind tests.
changing a word with their synonym that means exactly the same thing is neither smart nor proper. fact is, you're deliberately ignoring the aforementioned rule, and if you cannot respect a simple forum rule I question if you should be allowed to post here at all.
, yes, on topic and anyone who reports hearing a difference should post the specs of their cables and describe in detail as to what difference the cables have made to see if there is a consistent link.
No, no, a double blind test is only one specific form of blind test. "Unsighted test" and "blind test" would be synonyms, yes, but "double blind test" is definitely not. It is a subset and by no means is it directly implied when referring to "blind tests". So no, I'm not ignoring the rule.
Isnt it proved that ER4BSP - the only difference is the cable? They use the same driver and housing.
Proved enough for you, but to be really sure we would have to find out if everyone has the same experience. The issue is that people's experience of cables is inconsistent, which suggests subjectivity, which suggests it is all in the mind.
