Originally Posted by
BlackbeardBen /img/forum/go_quote.gif
Passive biamping is not of dubious usefulness. Once it's clear how an amplifier responds to a load (see above), it's easy to see in terms of available power how it still has benefits. Like I said, there's also the ability to control the gain to each section of the speaker, and the ability to vary your amps.
You can come over to my place when I get back to the US in June/July and I can show you, if you'd like. (I think I'm going to try to host a mini-meet.) You'll also get the chance to hear speakers that the HD 800 and T1 could only dream of being even in the same league of, performance wise...
Of course passive bi-amping is of dubious usefulness.
Are we talking 2-way or 3-way? I'll assume 2 since we aren't mentioning tri-amping.
Where's the crossover? Given that and the music being listened to, on a second-to-second basis: what percentage of the power is being drawn by the tweeter? What does the ohm curve look like on the tweeter?
It's unlikely that your load is 50/50, so you won't see a 3db advantage to bi-amping. You'll see the heavier-load driver get the power the lighter-load driver was eating.
Or if the issue is the ohm load, that's almost entirely an issue from the lower driver. You add nothing there by splitting off the tweeter.
And once we leave the technical discussion that the *best case* is 3d (and real case isn't that much), we discover that in almost all cases a more powerful single amp is cheaper than two lesser amps used for bi-amping (and even that has assumed the best case dual-amp bi-amping. If you are just using a multi-channel amp to bi-amp, then you are also still dealing with the limits of the (smaller) shared power supply).
Gain control already assumes that the crossover is mis-set (and remember that using amps in passive bi-amp for gain control divides in two blocks, with no slope, at wherever the crossover point is). No, far better frequency control can be had at the EQ than with something so crude.
No. Passive bi-amping isn't entirely ineffective but, in the vast bulk of situations this discussion happens under, will have no signifigant advantage over having not bi-amp'd and will actually be inferior to having spent the same money on a single larger amps.
The best case scenario for getting a twice as powerful
single amp to run your speakers is 3 dB, too...
Okay, I'm talking the Infinity Renaissance 90, a four-way speaker, passively biamped two ways with the dual-coil woofer being powered by an Adcom GFA-555 and the mid-bass, mid, and tweeter driven by a Carver TFM-15CB.
First of all, find me an amp that's as powerful as the triple nickel (200 W/ch into 8 ohms, 325 W/ch into 4 ohms, very stable into 2 ohm loads (probably around 450 W/ch), and capable of handling 1 ohm transients) plus that Carver (100 W/ch into 8 ohms, 150 W/ch into 4 ohms) for less than the combined price I paid for them ($300)...
The Ren 90s are nominal 4 ohm speakers, and because of the dual voice coil for the woofer (that lowers the impedance at the woofer's resonance frequency), its impedance curve is close to flat at 4 ohms down to 20 Hz. The mid-bass/mid/tweeter impedance rises as at higher frequencies, but I don't know exactly how much - there's no technical review for them online, although
another speaker using the same planar midrange and tweeter (but different mid-bass) goes from just about 3 ohms at the mid-bass to mid transition (600 Hz) to just shy of 9 ohms at about 35 kHz. I'm just going off
the white paper Infinity put out for them and its small graph (of dubious accuracy) that only goes up to 2000 Hz.
Note that I've put the more powerful amp on bottom - that woofer eats current like there's no tomorrow, thanks to the dual coils. It also puts out tighter bass than I thought was possible. The Adcom drives the woofer absolutely flawlessly by itself.
However, when I try to use
just the Adcom to power the whole speaker, the bass just isn't there. Hardly at all, anyway. It's either a crossover issue (which I haven't had time to investigate for bad caps), or an issue where the Adcom just can't provide enough current to the woofer when it's driving the mids/highs to a given level - at low levels I would guess that's hardly the case. It's not like I have a pair of 900 W into 4 ohms Krell monoblocks laying around to test that theory. The Ren 90s
are known for having light bass when underpowered. Anyway, when it's hooked up just to the woofers, the Adcom has no problem whatsoever.
The Carver has no problem keeping up with the Adcom. I don't know their respective gains, unfortunately. However, for balanced highs/mids with the fixed output of the Adcom to the woofer, the gain controls on the Carver go to somwhere around 2 o'clock. Like I said, gain control is one of the reasons to passively biamp, regardless of the other benefits or lack thereof.
I don't know how accurate they are, but the power meters on the Carver average around maybe -10 dB when playing at my limit of short-term hearing comfort. Transients go higher, of course - big bass spikes, like in, say
Angel by Massive Attack, go pretty high - but that's just energy dissipating into the crossover. I've never seen the meters peg out at +3 dB, which is what I presume to be the safe maximum transient output (averaged over the time it takes the needle to move). So - running out of power isn't close to being an issue for me with the Carver on top.
But, that's
exactly what's important.
The planar midrange and tweeter drivers are extremely delicate (
very thin Kapton diaphragms and aluminum traces) - bad clipping will destroy them almost immediately. (This is one reason soft clipping tube amps were recommended by Infinity for running the top half of their speakers.) The tweeter does have a self-resetting circuit breaker, which is good because they're usually the first driver damaged - but the midrange does not. That's bad news if I were to run one amp for the whole speaker and the amp were to current clip the signal at midrange frequencies. With separate amps, the current draw for the bass frequencies on the mids/tweeter amp is much lower thanks to the high impedance of the bass frequencies below the crossover - so the probability of current cliping is reduced to very small levels - not to mention that I can now monitor the amp's output with the meters. The Adcom does have handy distortion level indicators that will light up as clipping begins to occur, however.
So I hope you understand what I'm getting at here. There's more to it than just "MOAR POWER!". Then again, we're not talking about the vast bulk of situations - we're talking about big vintage Infinitys and their insatiable appetite for power.
