The qa360le isn’t mine, if I can borrow it again I shall do so![]()
Btw , may i know where are you located ?
SydneyBtw , may i know where are you located ?
Not sure this had been posted yet but just saw this from the china site
361 has 6 OPA1622 opamp chips internally.
For single-ended output (unbalanced 3.5mm)
Normal amp: Utilise 1 chip, Voltage output 10V
Large current: Utilise 3 chips, Voltage output 10V
High voltage: Utilise 1 chip, Voltage output 16-17V
Double high: Utilise 3 chips, Voltage output 16-17V
For balanced output (balanced 3.5mmpro)
Normal amp: Utilise 2 chip, Voltage output 10V
Large current: Utilise 6 chips, Voltage output 10V
High voltage: Utilise 2 chip, Voltage output 16-17V
They are not focusing on NA market currently I guess.Thanks for sharing .
Interesting is there's still no product introduction in English for this QA361 found at the official site.
The QA361 can only be found on the chinese version product page .
http://www.qlshifi.com/wzcp/qa361.htm
Very colourful and impressive spec .
It is a different size dap and until I can do a a side by side comparing I wouldn’t know. QA360 is great but big, BIG.
Spent a while away from the portable audio scene and come back to this! My QA360LE is jealous.
So this dap is using the AK4495SEQ but the kicker is that it is running at 7v rather than the standard 5v, only other dap to do this is the Yin Lu Mei D200+ (which I own and love), really a top DAC particularly at 7v. Also it is running dual power supplies (dual channel batteries like HM901 and Paw Gold), but this also has twin super capacitors backing the batteries, only other dap to use a super capacitor is WM1Z/A and QA360, but they only use a single super capacitor because of the single channel power supply. The OPA1622 are the latest audio opamp from TI, this dap uses 6 for balanced output, it is actually the same amp setup as the Fiio AM3 module. The LPF is OPA2107, doesn't get much better (same part as HM901 actually). Using PGA2311U volume control like the QA360. Overall looks to be a very well engineered dap. The QA360LE advantage is the Class A biased amp, but even then it is less powerful than the QA361, everything else is in favor of the QA361. Still the QA360LE has it's own sound and the limited edition has channel matched components which isn't feasible for mass production dap's, so I won't sell mine hehe.
