willco007
- Feb 20, 2008
Hi All,
I've just completed by build of a Pup DAC but alas, I've got a problem. I have audio but I have a pulsating noise; like a da-tha-da-tha that sort-of comes and goes. All my voltage test points are between .1 and .2 volts off of what they should be as well. I've checked my ICs for bridging and I *think* they are fine, but you never can tell. Any ideas what could be causing this?
EDIT: Also, on my Mac when I adjust the volume it has no effect; it's always full blast. I'm not sure if the volume buttons are supposed to effect the volume or not, but I thought I'd mention it.
Thanks in advance.
Thanks in advance.
