pigmode
Truck-Fi
- Jun 26, 2001
Would have been a good time to get a cullen IV. They are going for reasonable prices on audiogon, and not getting snapped up like before.
Which of these settings should I be using on my Macbook with the DLIII attached via optical?
I would set it for 24/96
In the opinion of those that have replied, is the DLIII (non-modded) the best way to spend $500 on a DAC?
I've got to be honest, it doesn't sound that much different than my Pico DAC only...
Thanks Graphicism.
I've had a few other DAC's in the past, but currently I'm A/B'ing the Pico vs DLIII on my Gilmore Lite by switching the RCA over between them. Both are using USB (to make it a common denominator between them). The only difference I hear is the DLIII has slightly more bass, but I don't consider that to be "better". I'm using my Magnum's as my reference phone and the same set of songs for each DAC.
I'm not complaining about the DLIII, I just don't hear the "synergy" I'd expect with an analog sounding DAC, revealing amp, and revealing phones. I was expecting "magic" but its kind of bland....
Surely 44.1 would be best, bit-perfect output and let the DAC do the upsampling. Otherwise you're introducing jitter and other junk and not letting the DLIII do it's job.
Not with the Mac - if the DAC is set for 24/96 and the music is 16/44.1 the DAC will still play it at 16/44.1, but you will get the full benefit when you play 24/96 music this way. If you leave it at 16/44.1 then when you play 24/96 music it will be down-sampled first.
Well I agree if you're going to be playing 24/96 it will need to be set as so, but for the majority of music 16/44.1 output from the computer will allow the DAC to up-sample. As far as I know the DAC isn't NOS with the options being 96 and 192. I don't know Mac's but if you set it to 24/96 won't typical files upsample from 16/44.1 to 24/96 before entering the DAC?
gosh, im torn between the DLIII schiit bifrost and the dacmagic.
is 400$ a reasonable price for a used DLIII?
ill be using it with a woo wa2.
im wondering if it will create too much of a warm tube sound when they are put together.
and how it compares to the other 2 dacs mentioned.
thoughts?
My understanding is the Mac doesn't up-sample, but it will down-sample if you are set for a lower bitrate than the music you are playing. And I forgot the DLIII up-samples everything, unlike the Perfectwave DAC that I bought to replace my DLIII. But with Mac the only up-sampling should be within the DLIII. I found the 96Khz mode to sound identical to the Stello DA100 Signature DAC with up-sampling turned on. The 192K mode was a little more airy and spacious sounding, and maybe a little brighter. With my HD800 rig I left it at 96Khz, and with my Stax SR-007 rig I left it at 192Khz.
thoughts?
I've seen them go as low as $500 but even then you don't know if you're getting something that's been tampored with, or perhaps a failed upgrade or something.
