gamefreak054
- Sep 3, 2011
Okay, thanks for info. Will now start looking at different tubes :3
I do have an Holland Bugle Boy 6DJ8 arriving tomorrow. I will see if my opinion changes then.
Generally they will give numbers like 76/78 or 90/93. The numbers represent how good a tube is. On my dads tester 80+ is good 60-70 is questionable and anything under is bad. I personally would not buy a tube under 85. I would try to look for tubes in the 90. You also generally want the numbers to be fairly close. Some tubes will only have 1 number as they only have 1 test you can give. I tested a microphonic tube that had test in the 70/73, and you had to make sure that tube was SECURE otherwise it would make very loud noises.
Love this thread. I have a sunrise II, is the ember much diff sound wise. I've read everything on G1217s site but wondered if owners had a take on it. I think I'm gonna get one just for the auto bias
I love my 6dj8s. Fave is a tfk 6922, followed soo closely by siemens 6922. I read somewhere in an article that the 6dj8/6922 is the best tube for audio YMMV. Based on your recommendations in the sunrise thread rmouser I have bought several 5751s and I have to say you are dead on. The sylvania is hard to beat!
Edit: If you do start buying 6dj8s know that there are no american made ones. Except for the amperex white label made in NY. All RCAs are rebrands. I have a siemens and mullard labeled rca. Sylvania might have made one...not sure
Thanks a lot - Looks like i missed that one.
This Sylvania one....http://www.ebay.com/itm/Sylvania-JAN-6dj8-ECC88-tube-Very-Strong-/181135663925?pt=Vintage_Electronics_R2&hash=item2a2c86e335
Good seller, have bought many tubes from him and always satisfied. Using this tube now and think it is the best of the tubes I now use.
Have these on the way in, so will have another 6dj8 to compare it with. If I like the sylvania one better, I am going to spring for another one from Tubemaze.
