Deaf ear
- Jun 2, 2016
https://www.head-fi.org/threads/vali-2-tube-rolling.793982/post-15600939
I don't know if anyone has tried the 7N7 or 7A4 tubes in the ember.
Ive used 7A4 and like them. I got an adapter from ebay seller: xulingmrs
Its the only adapter from her that isnt perfect. Which is why i dont use them much. She also sells an ecc88 - 6922 adapter that runs 6AG5wa pentodes in triode mode. They have a lot of mid bass and are kind of unique sounding.
Its nice ti see activity here. I have tried a ton of stuff, i just have a hard time quantifying it so i didnt write reviews.
I use a lot of 6N7 as well, and they are some of my favorites. I got a Visseaux 6N7 off of ebay for $35 and its really interesting. Tons of mids.
It should be noted i have single sided deafness so my ember plays dual mono so I'm sure there are Sonic qualities that I'm missing out on. Though I try to use it to my advantage because I can buy tubes that are imbalanced.
There are ton of nine pin triodes that will work with the Amber that are not on Jeremy's list of tubes. I don't know if there's a reason for that but ive looked them up and mathematically they work in ember. I'll try to post a list of them when I think of it. 6bs8 is one i like. 12bz7 is another. It can be pretty microphonic though.
