nwavesailor
- Nov 14, 2009
Alright, so I've only been able to listen for a few hours so these are very early impressions. The only tube I've tried so far is the GE black plate 5670, and for the most part it sounds great! Good detail and soundstage, and no channel imbalance. The drawbacks for me so far with this tube in the Ember v2 (w/LCD-X) is that there seems to be a bit of peakyness or zing to the treble, maybe around 12kHz or so. This works great with some recordings back can be a bit harsh with others. Also it's quite microphonic, as even touching the volume knob results in a sound. Neither the treble peak nor the microphonics were an issue for me with the Mjolnir 2, so either the Ember just doesn't play quite as well with this tube or they need some time to settle in. Time will tell. For the time being I do have some other 6DJ8/6922's to try, and have a Telefunken 12AU7 on the way to compare.
I think you will find a lot to like with 6DJ8 / 6922's, particularly if they are Ampererx/Philips 'Made in Holland' production. The 12AU7 should be nice as well although I have not heard a real Tele.
What I read, regarding the 5670's, was it was very difficult to find 1 that was NOT quite microphonic. What 5670 are you using?
