nix177
- Jul 12, 2016
An earth wire is a wire that connects a piece of equipment to earth. Here's an explanatory link:
http://www.bbc.co.uk/schools/gcsebitesize/science/add_aqa/electricity/householdelecrev5.shtml.
To earth a Faraday cage you attach the earth wire from the Farady cage to an earth point. The Faraday cage might work without being earthed, but mine needed earthing.
'Nearby redundant equaliser' means an equaliser which is positioned nearby but not being used. It has an earth point and that's what I attach the earth wire to. Not every piece of equipment has an earth point though.
Here's pictures of an earth wire attached by hooking through a hole in my Faraday cage which encloses a 6A6 tube in Ember, with the other end attached to an earth point on nearby equipment.
Note the 'Chassis Earth' symbol by the connector, and even though the equipment with the earth point is redundant and not powered up, it still needs to be plugged into the mains, and requires a mains plug with an earth pin.
Earth symbols can look slightly different. You can Google image those..
I was looking around the house. I don't have any equipment that has this "Chassis Earth" however I did look through some older posts on this thread. I see others using a copper wire to the thumb screws or use a copper wire and touch the top of the cap. Touching the cap sounded more dangerous.
I am going to revisit the foil idea tonight. Last time I didn't ground the foil so it didn't get rid of the earth hum. I will report back.
