- Apr 12, 2004
Just posted my review here: http://www.head-fi.org/products/garage1217-project-ember-hybrid-headphone-amplifier-preamp/reviews/10302
Thanks for the detailed review Asr! I was thinking about the Ember for my AT W1000x ( and a future HE500), but I am now hesitant with the noise issue (does the RCA 12AU7 completely solve the problem?). The Vali too seems to have some noise issues with the ATs, apart from the microphonics.
Great Review!
How about a comparison against other hybrid tube amps like the Lyr or Pan am.
Question about the pre-amp function, does it mute the pre-amp out when a headphone is plugged in?
Great review! A couple things though
As far as the hiss try high output impedance - that'll at least quiet it down if you get one.
Also experiment with high gain and bypassed input caps - I detect a sonic difference with both so the gain isn't just about volume in this case.
As far as 6DJ8s they're great tubes - My favorites are the Amperex offerings as well as a Tesla that I have
Nice one Asr!
One thing I took away from your review was that the higher gain tubes actually drive inefficient cans better. I thought the tube had no real effect on power output on the Ember?
I decided to purchase the Ember and asked Jeremy to do the Line out disconnect mod. Can't wait to get it!
Is it ok to change the output resistance while the amp is turned on?
