ebjred
Previously known as wredj10
Have a problem with the Bifrost, I am getting better sound from straight out of a cellphone.
I noticed the problem when tried with an amp so I tried an rca to 3.5mm adapter and the sound was noticeably worse. (The sound was similar to if I eq'd the bass and treble all the way down)
I have also tried different toslink cable, and getting the same sound.
Is there a way to fix this problem? Also, when using the rca to 3.5mm adapter is the sound normal if it sounds similar to eq'ing the bass and treble down?
