Nisbeth
- Oct 20, 2001
The shank is 3mm in diameter. I can't get them to fit in a META v 2.1 board. The standard hole size is 3,2 mm (exactly 1/8" or 125 mils) for an M3 screw to fit through. Enlarging the holes would be a nice thing (for the imperial-unit challenged
) If this is impossible for some reason, there _is_ an M2,5 (diameter 2,5 mm) but they are much harder to get hold of.
/U.
Originally posted by tangent Which part of the screw is 3mm? The shank, or the thread diameter, or the desired hole size, or...? Have you tried these screws in the META42 board's crossfeed mounting holes? These are the same size holes as we're currently using on the PPA board. The crossfeed mounting holes have been on the META42 since November and I have heard no complaints about it so far. |
/U.
