estreeter
- Jun 10, 2009
Hi All,
I get a little frustrated that there doesnt seem to be a 'standard' for expressing output power for a headphone amp. For speaker amps, it seems to be the number of Watts into an 8ohm load (sometimes 4ohm), but you will see various figures quoted for headphone amps.
For example, if the Fiio E9 has a rating of '1 Watt' ('16 ohm loaded') and the iBasso P4 has a stated output of 600x600mW into 32 ohms, what is the conversion from the Fiio figure into something I can compare with the P4 32 ohm figure ? Help
It gets worse on the Meier Audio site - here are some numbers for the Corda Swing:
Maximum output voltage 11V
Maximum peak output current 250 mA
Power uptake 2 Watts
Granted, it would help if I knew something about electronics, but they dont make it this hard to determine the impedance on a pair of headphones - why does it have to be this hard for amps ?
Thanks,
estreeter
Thanks,
estreeter
