Howie
- Dec 13, 2001
The issue here is budget and I do believe that the HC UO (you can buy a used one for $300 and slightly under) is by far the best one. It does give you surge protection, and it does give you sonic improvements. The fact that it has only 2 outlets is something to think about but I can tell you that the UO is something that is quite versatile and can be improved. Putting a really good powercord (the better the better) really makes a difference in terms of sound. If you don't like what it does to your sound you can always use it on video which is suppose to make an even better improvement if audio didn't do it.
I had originally bought UOs for my monoblocks but found dynamics to be constricted so I moved it to power my source to it. I'll probably do an A/B with and without the UO soon and would probably end up removing any UO from my audio chain but I would still keep it around as I like using it as a power extention to plug my TV into it. One thing it does do is make things more quiet although you can achieve better results with the use of better gear and better powercords still the UO does something for its price.
