infinitesymphony
- May 15, 2006
Run a dedicated line/branch with its own isolated ground from the main power circuit breaker to the outlet that powers your gear, if you can. That will isolate it from the other things in the house.
Conditioners like the Shunyata Hydra are well-reviewed simply because they don't affect the sound quality much versus the wall power. There's even a DIY Hydra website kicking around, and the cost in parts is far less than what they charge. Not to say that it doesn't work well, just that it seems a bit expensive given what's actually inside.
If I had the money, I'd probably go with either a professional power regenerator from APC, Furman, or Tripp-Lite ($,$$$), or something like one of the audio surge protectors from Brick Wall ($$$). They don't use MOVs for the surge protection stage, so the sound quality doesn't suffer nearly as much compared to those that do. I don't have the budget for either solution at the moment; I prefer to run straight out of the wall rather than use one of several power conditioners and strips that I've purchased, just because the sound quality difference is so significant, IMO.
If you didn't have potential ground loop problems and were happy with the sound from the wall, I'd recommend the cheapest surge protector you could find (ex. Newpoint or no-name brand, $10 or less at your local hardware store). These have minimal components and affect the sound less than power conditioners or line filters.
