OK, thanks. You confirm what I said in my original post. "The common answer is "try it and see" (OK, try it and hear)", but my original question was is there a way to objectively test a cable to the properties that may make it help product better sound? Clearly a few on this thread do not feel it's possible, since they don't see how a cable could affect sound (except a very poorly designed one, or a cable designed to alter the power is such a way as to color the sound). And there are those that feel a power cable can have an affect. This long running argument is the objectivists vs the subjectivists. I was hoping to avoid that discussion and focus on ways to test.
I'm an objectivist. if I cannot tell the sonic difference between two audio sounds in a blind test, I don't see any different between them. Unfortunately, I really don't trust comments about comparing two quality products unless there has been some sort of blind test. I also don't understand people's reluctance to perform them. Yes, the militant objectivist will say the subjectivists are scared of the results. No need to argue down that road.
The blind test does not tell you everything. Let's say you hear a difference and you know a new cable is installed because you not only hear it but also
see it (or someone tells you it's been installed). This is still part of your human experience and if it's in an improvement to you, why discount that?
Or, in same scenario, you may notice no difference. Both scenarios are part of your own experience and should not be discounted. What should be discounted is others telling you about it one way or the other, without you having actually heard it for yourself.
