So, I have the ATC SCM11s burnt in for two weeks. First impressions are really, really good.
Just a few remarks before giving a full report:
The speakers right out of the box sounded good, although a little flat. It took about ten days till they developed enough punch in the bass area, while highs were excellent right from the start. I guess the speakers haven't settled in fully, so the bass region might still develop a bit. If so, all the better.
The sound is extremely revealing and transparent. A delight.
I had to get used to the Lab.Gruppen IPD 1200 amp. It is extremely powerful, so one has to play around with taming it. The input level needs to be cut to about -25 dB, otherwise the pre-amp of the GSX-Mk2 delivers too much power. Also, at 0 dB input, the amp hisses just a bit, which is not audible when music is playing. But I prefer a silent amp.
I also played about with my set-up. First I streamed music from my Aurender N100H to the DAC. This sounded very pleasantly, and since the speakers hadn't settled completely, it sounded a little lifeless. I then switched to feeding music to my DAC via the Audirvana 3.1 beta. In parallel, the speakers settled better, and at first listen, the sound was very detailed and with lots of bass. However, after a few hours of listening, I noticed that I was getting sensitive to some digital glare getting through the Audirvana. Same thing when I switched to Room, although not as pronounced. So I switched back to the Aurender and, voilà, there it was it again: very smooth sound, without any sharpness and brightness. So I'll stay with my Aurender, all perfectly well controllable va my iPAD.
