Post your computer specs!~
Mar 13, 2012 at 12:17 PM Post #1,502 of 3,145
LGA775 dual core or quad? If it's a quad you should be fine for now, although you'd certainly see better FPS with a newer processor tech like Sandy Bridge. If it's a dual core then that is going to be a serious bottleneck for sure. I guess I'd recommend you just overclock the CPU as much as you can until you can afford to upgrade to a newer platform.
All bottlenecks aside, what seems to suffer the most with an older platform is your minimum FPS. Even if we both get the same Max FPS, your minimum might be a lot lower than mine. This means that you'll have those times where your FPS drops down so much that the game stutters or even seems to lag out for a moment.
Mar 13, 2012 at 7:22 PM Post #1,503 of 3,145
It should be a dual core. With all the ivy bridge stuff coming out, the sandy bridge stuff is surely going to have a price drop, I'll take advantage of that later when it happens. The benchmark of the dual cores looks good enough for now. I'm not certain about overclocking since the PC is after all, a little old, and my cousin is the type that leaves them running all day.
Mar 13, 2012 at 11:16 PM Post #1,504 of 3,145
My computer specs, build this more than 2 years ago, have only upgraded the 460 GTX to an 6950 and replaced the HDD with a SSD for OS and applications. I use my samsung 40inch full HD tv as a monitor.
Case: Coolermaster HAF 922
CPU: AMD Phenom II 955 BE @ 3,6Ghz
CPU cooler: Zalman CNPS 9700NT
GPU: Sapphire 6950 1GB
RAM: OCZ platinum 2x2GB
MB: ASUS M4A785TD-M EVO
PSU: OCZ ModXstream 700Watt
OS drive: Crucial M4 64GB
Internal drive:
WD 500GB
Pioneer DVR17J dvd writer
External:
Lacie 250 and 320GB
Toshiba storE 1TB
Mar 17, 2012 at 8:58 AM Post #1,505 of 3,145
Been going through gear quite alot this last year, but finally landed on the following rig specs:
NZXT H2 case
Asus P67 Sabertooth B3rev
i7 2600k running at 4,4Ghz
Corsair H80 With Gentle Typhoon 1850:s in PnP
16Gb Corsair Vengeance
Asus 6970 DirectCu2
Asus Xonar Essence ST
Intel 320 120Gb
3x2Tb Western Digital Green
Mar 18, 2012 at 3:49 PM Post #1,506 of 3,145
800d w/ RX360 topmount, swiftech & xspc blocks, EKwater pump
2600k @4.5ghz
Gskill 2133 ram
Gtx480 w/ bios hacked and unlocked
Agility3+caviarblack in hybrid raid/smartresponse mode
Aerocool blackshark 140/120 fans
Sent from my T-Mobile G2 using Tapatalk
Mar 31, 2012 at 2:09 AM Post #1,507 of 3,145
After numerous problems (infinite boot loop, voltage issues*, incredibly long start up times, an absolutely pathetic EFI**, etc.) my motherboard has decided to stop displaying any video (and no, it's not the GPU - the system just doesn't boot far enough for the GPU's to start up). I put my 2600K on eBay. I wanted to upgrade anyway. I picked up a 128GB Samsung 830 SSD and will get a new mobo/cpu soon. Socket 2011 here I come.
*1.45v for 4.5 GHz on the MSI mobo.1.32v for 4.5GHz on an ASUS board. The voltage also went up under load. So ridiculous.
**Up was down and down was up, childish color scheme/layout, etc.
Good riddance to a horrible motherboard.
Mar 31, 2012 at 9:20 AM Post #1,508 of 3,145
That has never happened before, so don't count on it.
Anyway, my specs
Intel i5-2500k
HD 6870
Gigabyte Z68MA-D2H-B3
Intel 320 120gb SSD
Barracuda green 2tb HDD
Corsair 650watt PSU
Corsair XMS3 RAM 8gb 1333
Corsair 400r case
Apr 7, 2012 at 2:03 PM Post #1,511 of 3,145
i5 750 (Noctua NH-U12P)
Asus Maximus III Gene
Asus GTX580
8gb Corsair Vengeance
120gb Samsung 830 SSD
2tb Samsung Spinpoint F4
1tb Samsung F3
500gb Hitachi somethingsomething
Corsair Obsidian 800D
Apr 13, 2012 at 12:53 PM Post #1,512 of 3,145
I've ordered an AsRock x79 Extreme6 motherboard and recently picked up 8 GB worth of Samsung's 30nm ram. Supposed to be really good for stability/overclocking. I'll get an i7 3820 within a week.
Apr 14, 2012 at 2:07 AM Post #1,513 of 3,145
HP DV6
amd radeon hd 6770
intel core i7 2630 qm
15.6 inch 1366 x 768
Superbly epic awesome mega beats audio (lol jk, I don't love it but I still have it)
Apr 14, 2012 at 6:19 AM Post #1,514 of 3,145
I just wanna take a moment to shat all over my corsair f90 ssd. From day 1, I dealt with f4's in brilliant blue. I tolerated having quick boot disabled for nearly a year to reduce thes occurrences. Late last month, @ midnight on Friday, in the middle of a very enjoyable BF3 session...she blue screened and never came back.
I learned 2 things from this.
1. Intel SSD's are worth their price premium.
2. Yearly backups don't cut it. ;)
Edit:...missed this...
...and recently picked up 8 GB worth of Samsung's 30nm ram. Supposed to be really good for stability/overclocking.
That stuff is AWESOME. I have an Asus P7p55d-e pro with a mild 3.6ghz oc and an i5 760. For a year I ran 2x2 of g.skills Eco cl7 and never had a ram related issue. The bf3 runs better on 8 claims eventually got to me and I tried corsairs low profile low voltage vengeance line...2x4. I got 7e's and never passed more than a few intel burn runs. Upping imc vtt and vdimm did nothing. Same results with some mushkin 1.5v cl8 2x4's. Finally, I gave these $40 wonder toys a shot. Not only are they stable @ 1.35 cl7, but I'm running 4x4 with no changes on the voltage front for imc or CPU! Worst packaging ever, sure. But between the intel ssd and this ram, I can sleep the pc again for the first time in a year without having to worry about any crashing. Thankfully, I've yet to see a blue screen with this combo. A+, highly recommend this ram.
Edit: They are actually shorter than the dimm clips, making ram sink vs heat sink fights a thing of the past.
Apr 14, 2012 at 9:12 AM Post #1,515 of 3,145
Copy and paste from [H]
MAIN/Streamer:
i7 960@4.3GHZ/ Noctua D14 Push/Pull config. (Spare 990x lying around haven't bothered installing)
24GB Mushkin DDR3 2000 Black RidgeBack
Asus Rampage II Extreme
3xGTX465 Overclocked (2x ECS + 1x Gigabyte) - Got 3x GTX680's haven't installed awaiting PSU upgrade
X-Fi Titanium Pro Fatal1ty
5x2TB WD Green and Seagate LP, 1TB Hitachi, 2x750GB Samsung, 2x 120GB OCZ Vertex Plus SSD Raid 0
Enermax 1250W Revolution85+ PSU
Antec P280 Case
Logitech G110 Keyboard
Logitech G9 and Razer Deathadder v2 (use both)
HTPC:
Q6600@3GHZ
4GB Kingston DDR2 800
Gigabyte G31M-ES2L
Kingston ssdnow v1 64GB SSD, 2x1TB Seagate Barracuda's
Gigabyte GTS450
TP Link WMP300N
Gigabyte ODIN 720Watt PSU
HP m8070a case
NETBOOK for work/uni:
Asus 1215N
4GB DDR3 RAM upgrade
500GB Hitachi drive upgrade
12.1 inch LED screen
And no I rarely or don't play games.
