elvispreasley
That's quite a stack.
What are the advantages of this system compared to using a small dnla capable DAP such as the Hiby R2?
The short answer is - a lot.
To be more specific. I don't have an experience with R2, but used R3 as a transport before I moved on to Beaglebone and it far less convinient. First of all, R3 can't play some of the albums from Tidal. Not a lot, but the fact is still remains. Second, R3 can't play gappless with Tidal, which is pretty annoying, especially when you're listening 100+ tracks album of the trance music, where all songs creating one long composition. Third, it's tricky to navigate through your music library with such a small screen. Fourth, R3 has no MyMixes in its Tidal.
The beaglebone itself is absolutely outstanding transport even with stationary setup, so in portable it's simply unbeatable. With simple and light weight custom OS (Linux based) it shows only streaming protocols to chose from (check the attached screenshot) and can be used as an end point for Roon, streaming your local music library from Audirvana through UpNP and the most important for me - playing the music through the Tidal Connect, which streams directly from the Tidal web servers, avoiding all of the software players, codecs and everything else, which may affect SQ, despite of the bitperfect. Also the official Tidal app might be used for navigation, which is super convenient and gives you the maximum available features.
