elvispreasley
Just got my B4-x. Unfortunately it appears to be from the new batch with a different type of tubes. Unluckily I spent about 40$ on few different pairs of 5899 tubes, thinking to make it replacable on my amp) Well, hope someday I'll find out what to do with them...
The amp came with 2 Burnson V5i op amps (which I also ordered), so I installed them right away. Also I covered the inner part of the amp metal body with faradey tape and put 2 silicone rings on each tubes. Another words, did some basic mod straight out of the box.
I still need more time to realize - do I like the sound with this amp better then with the built in amp of my portable multibit dac/amp (Tento 1866), but I already have one concern. The amp has very noticeable "hiss" noise on the background. When the music is playing it's kinda hard to hear it, so it's not really affecting a lot the overall sound of the amp during this time, but when the music is not playing - the "hiss" noise is really easy to hear. I do have an experience with several tube and hybrid amps, but never ever heard anything like this, as they usually had quite black background. Is this a typical situation with B4-x or my particular amp has some problem, which cause this effect? If there any chance to fix it?
UPD: Just found out that the hiss exists only with low impedance and high sensitivity earbuds/earphones (32 ohm, 115db as a particular example). With 600ohm earbuds, B4-x has fairly black background.
