Portable Sabaj Amp/DACs
Mar 19, 2020 at 7:04 AM Post #76 of 86
2.5 mm TRRS is the most common and that's the one that should work with Sabaj.
The important question here is what would you like to attach on the other end of that cable? Also, can you give a link for that TRN cable that doesn't work so we can maybe get into the heart of a problem?
Mar 19, 2020 at 4:58 PM Post #77 of 86
Was wanting to use it with any of my 0.75/78 mm 2-pin connector IEMs, if that's what you mean? Here is link
#Aliexpress NZ$ 20.01 40%OFF | TRN 16 Core Silver Plated 2.5/3.5/4.4mm Balanced Cable To 0.75 0.78 2pin/mmcx Connector Hifi Upgrade Cable For TRN V80/KZ/TFZ
https://a.aliexpress.com/_BTYFsz
Plus screenshots of the actual one I received... Thankyou very much for responding!
Mar 21, 2020 at 3:39 PM Post #78 of 86
On the pictures you attached is shown a single-ended 3.5 mm (not balanced)... If you want to use a balanced connection you need this one I attached. It's also needed to choose a balanced connection in the menu of Sabaj Da3.
Mar 21, 2020 at 10:21 PM Post #79 of 86
Hiya. In the large selection from which my screenshots were taken, there is no option listed as TRRS. And I cannot find one in that selection to correspond to your picture, which strangely, looks to come from the same item listing . The one I selected and received was listed under the general heading of 'balanced cable'. But all TRN. I am very confused!
Indeed, when I plugged it into the DA3 it read out UNBAL and would not change that no matter what I did with the menu button!
IIs it possible you could find a link to that very same TRRS one pictured?
Thankyou again, very muchly!
Apr 3, 2020 at 4:26 PM Post #84 of 86
TRN is just the name of the brand. TRRS is a standard used on 4-pole audio jack... don't worry about it.
