Portable Case for UE10 Pro
Oct 2, 2005 at 10:22 PM Thread Starter Post #1 of 19
solvexyz
I was wondering what portable case do you use for UE10 Pro. Can the Shure portable case be able to hold the UE10 Pro?
Oct 2, 2005 at 11:00 PM Post #2 of 19
I have pulled out the plastic spool from my E3s' case so as to get the room for 2X-S. They can be stored there, though the case is rather tight. Whenever I don't use them (which doesn't happen often
), they either hang from my neck or I put them into my pocket (a secure and not tight pocket, like the one on a shirt, suit, etc.).
Oct 2, 2005 at 11:06 PM Post #3 of 19
Are you talking about those smallish, round cases from Shure?? Hell, I didn't even dared to jam my E2Cs into it. I doubt the UE10s will fit in there - I guess the same applies for the UE case. I thought of using a pen case instead so it would be big enough and I won't have to loop up the wire.
Ciao,
Marcus
Oct 2, 2005 at 11:17 PM Post #4 of 19
UE's should fit as well when the spool from the Shure case is out, but the fit is definitely tight. We need to find some other, more appropriate solutions, I guess.
Oct 2, 2005 at 11:23 PM Post #5 of 19
I have looked around a bit lately as I had the same worries as solvexyz, but have not found a solution besides the mentioned pen case.
Has anyone asked UE about a solution? As they're pushing into the consumer market I think they will/should look into a portable case - just like they did for the super.fis.
Ciao,
Marcus
Oct 2, 2005 at 11:25 PM Post #6 of 19
This may sound dumbd, but how do you take the spool out of those Shure cases anyway? I want to take mine out as I fear for the cable connection on the phones.
Oct 2, 2005 at 11:31 PM Post #7 of 19
You need some pliers and some nimble fingers, that will do
. However, when you pool the spool out there are two little holes in the case where the spool was originally placed (you can call'em "ventilation holes"
Oct 2, 2005 at 11:44 PM Post #8 of 19
Won't they fit in the UM2 case? It's a bit larger than the Shure offering and has no spool to take up room.
Oct 2, 2005 at 11:59 PM Post #9 of 19
Yeah, I try to put my Westone UM2 in the Shure case, and it is rather tight fit. I pretty sure UE10 Pro is going to be a lot bigger than UM2, so it seems to me it will not be a good idea to jam such expensive IEM into that. Anybody tried the super.fi metallic case? Will that do it?
Oct 3, 2005 at 12:02 AM Post #10 of 19
although larger than the above mentioned shure spool cases, the otterbox 1000 or similar pelican case are AWSOME for protection.
i have photos of my mom's car ontop of my otterbox with er4p's in it. also in a sink full of water.
if you use a SMALL portable player (probably only flash) it will probably fit in there too.
Oct 3, 2005 at 12:09 AM Post #11 of 19
solvexyz - just take a look at the following picture and I believe you will agree with me that they might be too small (look like as they are almost as big as the shure cases): http://www.ultimateears.com/superfi/..._sept-2005.jpg
EDIT: he nikongod, the otterbox 1000 looks indeed promising. They are even available in Germany - just found them in a diving shop. With it's size of 11x7x3,5 [cm] they probably fit the UE10s - maybe a little foam is needed to make sure the IEMs are "comfortable".
Oct 3, 2005 at 12:13 AM Post #12 of 19
Yeah, thanks MarcusH. I think it is ganna be too small for UE10 Pro. I really hope a smaller and more portable version of the Westone Pelican case for UE10 Pro is available - Waterproof + ability to survive a holocaust.
Edit: Wow, just did a search for otterbox 1000, and it maybe be the answer to my Portable version of the Westone Pelican case. Thanks, nikongod.
Oct 3, 2005 at 1:46 AM Post #13 of 19
It will of course depend upon the size of your individual pieces, but mine fit the Shure clam shell. It's a very tight fit though. They also fit the UE Super.Fi leather pouch but it's not very sturdy. I really wish UE would make a portable case available for it that was sturdy and compact.
They also fit the metal Super.Fi 5 case if you pull out the plastic spool, but it's a little akward to put it in, and I'm not sure if the metal will scratch the surface of the UE-10s. I suppose it would be easy enough to line it with something.
I just tried to fit it in a mint tin and it's a little to shallow for mine. Of course, YMMV.
Oct 3, 2005 at 1:52 AM Post #14 of 19
I just got my UM2's and that case should easily fit UE10's.
Oct 3, 2005 at 2:32 AM Post #15 of 19
