LFF
Co-Organizer for Can Jam '09
Member of the Trade: Paradox
- Dec 6, 2004
After our chat the other day that is exactly what I did. Mine fit perfectly inside the Super.fi case and it still remains crush-proof. Moreover, the way I put mine in allows for easy winding of the cord and a 1/4 inch adaptor. I guess it depends on the size of each persons UE-10's.
Originally Posted by Jasper994 They also fit the metal Super.Fi 5 case if you pull out the plastic spool, but it's a little akward to put it in, and I'm not sure if the metal will scratch the surface of the UE-10s. I suppose it would be easy enough to line it with something. |
