Great quickie review. Keep your thoughts coming!
Ok...last but not least onto
mobile rig testing of the pono. This is a real world test...I'm in a coffee shop.
Up until now my mobile rig consisted of a macbook pro with Audirvana 1.5 driving a Audioquest Dragonfly 24/96 DAC and a Ray Samuels Hornet amp driving Shure SE535's all connected with Moon Audio Silver Dragon cables (both custom for the Shure's and also a short run to go between the DAC and amp). The Dragonfly was cheap and convenient (small) but does not give the sound performance of the Meridian Explorer I use on my home computer. Note my earlier post about comparing the pono/ayre to the meridian using a little dot MK9 with Audeze LCD-2s
So the comparison in this case is between:
1. macbook pro/Audirvana 1.5 with a Audioquest Dragonfly 24/96 DAC and a Ray Samuels Hornet amp driving Shure SE535's all connected with Moon Audio Silver Dragon cables.
2. pono/ayre with a Ray Samuels Hornet amp driving Shure SE535's all connected with Moon Audio Silver Dragon cables.
3. pono-ayre driving Shure SE535's all connected with Moon Audio Silver Dragon cables.
I'm going to use three audio files for testing.
1. Walk Across the Rooftops from The Blue Nile...24/96 rip of original UK vinyl made with my Lynx Hilo AD/DA from my Rega RP6 processed through my Cary SLP98 tube preamp.
2. Herbie Hancock "Chameleon" from Headhunter...this was a 24/96 file provided with my HH Signature pono.
3. Dick Hyman Motet Swing from Reference recordings (24/176)
I did my best to adjust volume to equivalent levels.
Blue Nile
-compared to the audioquest the pono/ayre has a much broader sound stage. the bass is much more detailed.
-the hornet amp really helps the bass in my opinion...its fuller directly from the pono/ayre, but its better detailed and has better space around the drums going through the hornet amp.
-I would choose the pono/ayre in a second over the dragonfly with or without the hornet.
HH Chameleon
-no contest between the pono/ayre and the dragonfly...drums are real through the pono/ayre...not as phat...real...detailed...tight...the drum/bass solo is outstandingly groovy...damn...the 70's!...I grew up with this tune performed by Maynard Ferguson...but herbie takes the day.
-once again the hornet does a better job than the pono/ayre amp...more detail...the pono/ayre just has more thud...I suppose the hip hop crowd will probably like that sound...but I know what drums and bass actually sound like...and the pono/ayre / hornet gets it best...but it should for an extra $400...the pono/ayre by itself is completely listenable however...much better than the dragonfly.
Dick Hyman
-this is a light atmospheric piano centered track...with an acoustic small big band...recorded at 24/176 by Dr. Johnson...recording quality doesn't get any better
-the pono/ayre with hornet is really ectasy on this track...I feel like I'm playing my playing my trombone in the gig...completely natural sound stage...the piano is real...I can tell the type of mute on the trumpet. The decay on the snare rattles is right on the pono/ayre compared to the dragonfly.
-note on this file Audirvana has to downsample because the track is 24/176 and the DAC is only 24/96.
Thus, I'd say the pono is a big improvement over my dragonfly...I also like having a stand alone music rig that is independent of my laptop.
