Jun 16, 2016 at 3:29 PM Post #31 of 72
I got mine for about a week now. Overall the sound is FLAT and detailed, so not in a bad way but flat with the meaning of relatively neutral.Maybe the mids stand a tiny bit above bass and treble but very slightly.Separation is also quite good and the sound-stage is quite big for an iem, about on par with the trinity Delta and 1more Hybrid eo323 wich i also own. I really can't say anything negativ about them although I like the other two more but just because if their slightly bigger amount of bass and cosequenly more versatile iem for me which is always my headphone criteria number one
Got mine about 2 hours ago.
I have to agree with much of what Flib has said.,he is right on the money.
I would say,they are neutral to slightly bright,with excellent detail & clarity.
They comes in a nice little box,with a suede zippered case,that hold the additional tips,and the earphones,very compact....nice.
Build quality on the earphones seems to be very good,and the fit ,for me,OOTB if fine/comfortable.
I will burn them in for a week or so,& try additional tips,that were supplied..
Dollar Vs SQ/build ,as of now,I would rate these as a 9-9+.,this may change after a week or two?
Bass is slightly weak...mids are dominant,but in a good way.,vocals,especially female vocals are excellent..treble is very clean & detailed.
I am using them,now,on my desktop setup...Asgaard2 amp/gungnirMB dac.
I will try to make a comparison between these,and my 1More triple driver's...as they are both 3 driver,and more or,less in the same price range{under $100.00}
Mike
Jun 16, 2016 at 4:01 PM Post #32 of 72
@mikek200
If you still find the bass a little too weak for your liking after some time of brain-in, try a tape mod (sticking a small stripe of tape on the vent along with probably piercing a very small pinhole into it).
Similar to DUNU's Titan in-ear series, the A 01's bass quantity will highly depend on your ear shape and the consequent varying proximity of the vent to the ears' Conchas. Small proximity = less bass, greater proximity = more bass quantity.
Nonetheless, these are sonically great in-ears for their respective price point.
Jun 16, 2016 at 7:22 PM Post #34 of 72
  @mikek200
Thanks Chris,
I'll give it 100 hrs.,and see where I stand..
I don't want to turn this thread into another QT5 thread-LOL
If after a few weeks,I find the bass still lacking,I'll just EQ it a bit.
Don't really feel like taping it,or,sticking pins in it...although,might be a good idea
We can re-name these IEMS to the... super VODOO version.
Also,I plan on getting the SW3's in a few weeks{I think?},,so that will be another bright earphone
Thanks,
Mike
