Genuinely impressed with the new X8 version of the Tri-Silver. One of the nicest cable builds I have yet handled and does not feel like a bulky 8-wire at all.
1. Any chance you'll redo existing heatshrink connectors with the new ones if we send it in? I'm not iffy if there's a fee for that.
2. The 2 pins on my Tri-Copper are nice and slide in with my Zeus, but tend to slides off over time and I'm worried about having the earpiece fall off, are there any recommendations you have for getting a more snug fit?
Last review for the week comes from Yago over at Oldnewsound.es. He spent months with our Tri-Copper Type 6 Litz wire and had the following to say:
"If you prioritize the naturalness, richness in details and smoothness of treble, without giving up a good extension, this is your cable. The details and quality of finishes are also first level, we could perfectly put it as the "example of the class" to follow by others."
Review by @twister6 on Exo Series cable with Tri-Silver Type 6 Litz wires has just be published! He concludes, “The common change I found while switching to Tri-Silver cable was always an improvement in soundstage width expansion, giving the sound a more holographic perception. Furthermore, it gave low end more control, making it tighter and better separated from lower mids. The most noticeable change was in upper mids, bringing more focus (instead of being further out of your head), making them sound more natural, and lifting the quantity to make sound sig more balanced.”
1. I have pretty oily skin and it's been causing the segments around my ears to harden considerably. I was wondering if there was a way to prevent the cable from hardening. Could I order cables with a short segment of cloth around the ear?
2. Can you make cables with memory wire ear guides?
The Headphone List has published their review on the X8 Series cable featuring Silver + Gold wires. Writer Caleb aka @PinkyPowers had the following to say after using it for months: "This is a cable which quite simply gives you more of everything. More clarity. More bass. More energy. Bigger stage. More… excitement. If you’re looking for a nice jump up over your stock cable, but don’t want to spend all the monies, this is a great choice."
Read the full review at https://theheadphonelist.com/to-dazzle-and-dominate-a-review-of-the-plussound-x8-silvergold/
The X8 Silver + Gold pairs wonderfully with my Campfire Equinox. This pairing brings out more details out of the Equinox, wider soundstage, and holds that powerful bass in check.
Exo Series Custom Bluetooth Cable for CIEM / 2-Pin / 0.78mm
Wire: Copper (Type 6 Litz)
Slider: PS Black Aluminum
Left: PS Blue Aluminum
Right: PS Red Aluminum
