Plussound Audio Thread
Aug 28, 2018 at 8:08 PM Post #932 of 1,759
Is the shrink wrap removable or does it hold something in place? Additionally how can I quickly remove the branding on top of the shrink wrap?
We've sent a PM to help you out.
PlusSound Stay updated on PlusSound at their sponsor profile on Head-Fi.
https://www.facebook.com/plusSound/ https://twitter.com/plussoundaudio http://plussoundaudio.com/
Aug 29, 2018 at 11:50 AM Post #934 of 1,759
I bought a pair of these for my Unique Melody Merlin's (yeah, they're old, but also great) and use with my Pixel 2.
Pros:
- I received exactly what I ordered, in a time frame slightly faster than what was anticipated
- build quality is excellent
- looks amazing
- the two-pin socket fits perfectly in my CIEM's; nice and snug, but not hard to insert or remove
- some have complained about the loud beeping; the fix for lowing the beeping volume presented by Plussound elsewhere in this thread does work, and at least so far, has been persistent. I have no issues with loud, painful beeping.
- easy pairing, which has so far worked as expected
- sound quality: these sound pretty good, meeting my expectations for audio quality with aptX. The character of my headphones is definitely preserved. More below in the "cons" section.
- does work for phone calls, although I have only used this once and can't thoroughly evaluate
Cons:
- as described by others, there is a bit of a hiss with my sensitive (12 ohm) IEM's. I do not finding this problematic as I purchased this cable for my IEM's which I use in public, so there is already background noise and darkness is not required. I have definitely heard louder hiss with these IEM's on other amps, so for me, this is fine.
- Bluetooth 4.2 with aptX. Because of these technical limitations, there is less latency than with SBC, but there is still enough latency that these aren't great for gaming. The sound lag is tolerable, but definitely noticable. Additionally, the sound quality is what one would expect for aptX; clearly not as good as wired with a good amp, with some less in fidelity, sound stage, and detail. I put this in the cons section in hopes that a future revision might adopt Bluetooth 5.0 and/or higher quality audio codecs like aptX HD, LDAC, and so on, but honestly, the SQ is slightly better than I was anticipating given aptX.
- Uses a micro USB plug. Come on, this ain't 2015, upgrade to USB-C!
Overall, I'm pretty happy, and got exactly what I expected/hoped for. I know the "cons" section above looks long, but it really isn't; if you are looking for a way to Bluetootherize your IEM's for working out, use in public, etc, these are a great choice and get the job done in style. If you want to preserve the highest of audiophile-quality experiences, don't get this, as there is a loss in SQ (which should be expected; you're buying something using aptX!) The SQ is better than I expected, and is competitive with the SQ I get using the Pixel 2 included USB-C dongle. I would definitely buy these again.
00100dPORTRAIT_00100_BURST20180829094620300_COVER.jpg IMG_20180829_094535.jpg
Aug 29, 2018 at 1:14 PM Post #935 of 1,759
Thanks for sharing your impressions @Bazirker!
Sep 2, 2018 at 10:56 AM Post #940 of 1,759
Sep 2, 2018 at 2:10 PM Post #941 of 1,759
X6 Series Custom Cable for Dual 2.5mm (HiFiMan / Audioquest / Oppo)
Wire: Copper (Type 6 Litz)
Braid: Semi-Round
LR Braid: Flat
Termination: PS 2.5mm TRRS Balanced
Y-Splitter: PS Black Aluminum
Slider: PS Rose Gold Aluminum​
Sep 3, 2018 at 12:29 AM Post #942 of 1,759
Hey Christian & folks,
I have a PS silver+gold with UE connectors lying around for a while and now I have a couple of candidates to pair it with.
BIG question: how do you guys at Plussound align the polarity of the 2 pins in the UE connector? is it front + / rear - or front - /rear +? Thanks!
Sep 5, 2018 at 9:19 PM Post #943 of 1,759
We've sent a PM!
Sep 5, 2018 at 9:20 PM Post #944 of 1,759
Exo Series Custom Cable for MMCX
Braid: Round
Termination: PS Gold Plated 3.5mm
Y-Splitter: PS Gold Aluminum
Slider: PS Silver Aluminum​
Sep 7, 2018 at 7:27 PM Post #945 of 1,759
X8 Series Custom Cable for 2-Pin / 0.78mm / CIEM
Wire: Silver + Gold (Type 6 Litz)
Braid: Square
LR Braid: Twist
Termination: PS Gold Plated 4.4mm TRRRS Balanced
