Plussound Audio Thread
- Thread starter achl354
PlusSound Exo series cable
PlusSound Exo series cable unboxing - with their new t-metal type 6 litz wires. It is comprised of gold plated copper and silver + gold. The Y-splitter is gold aluminum and the slider is silver aluminum. Termination is 2.5mm trrs plug.
PlusSound Exo series cable, Campfire Audio Andromeda, PlusSound 2.5mm female to kobiconn adapter, CEntrance Mini-M8 to Opus #1 via ALO Audio optical cable.
With Campfire Audio Dorado
PlusSound Kobiconn to 2.5mm balanced adapter
IBasso DX200 and IT03
Exo Series Custom Cable for Interconnect
Wire: Copper (Type 6 Litz)
Braid: Round
Configuration: 3.5mm TRRS to PS 4.4mm TRRRS
Stay updated on PlusSound at their sponsor profile on Head-Fi.
I knew I'd start seeing some 4.4mm adapters
X8 Series Custom Cable for 2-Pin/0.78mm/CIEM
Wire: Gold Plated Silver (Type 6 Litz)
Braid: Square
LR Braid: Round
Termination: PS 4.4mm TRRRS Balanced
Y-Splitter: PS Carbon Fiber
Richsvt
Finally got my Noble X and used my new X6. Very nice pairing so far...nice work Christian. Excellent craftsmanship. (realized I put the cables upside down, corrected since the picture)
PLUSSOUND Cryo Treated 4.4mm (5-Pole) TRRRS plug is now available to purchase for DIY.
Features include:
High conductive base metal
Contacts are surfaced plated with gold for maximum performance
Thick anodized aluminum enclosure
Cryogenically treated before assembly for enhanced strength
illenium
- Mar 30, 2017
hi i'm looking for an upgrade cable for my campfire vegas and am interested in plussound. could i get a recommendation for a cable that will expand the soundstage and also give more extension to the highs? read some reviews on the X8 GPS and would like some opinions on whether this cable will be it or are there other cables in your collection that have the mentioned qualities.
thanks a lot!
thanks a lot!
AndrewCanDo
thanks a lot!
Truth be told, that sounds like the qualities a silver cable would provide. Id probably suggest the '
Pure Silver Type 6 Litz ' if you're looking for an expansion to the sound stage and the highs.
Id also recommend you look at the PlusSound "About" page. It provides a description for each wire type and what changes they offer sonically. http://www.plussoundaudio.com/about.html
thanks a lot!
Pure Silver would be the recommended choice. Feel free to PM or email us for more recommendations and if you have more questions.
Micro Series Adapter
Configuration: 2.5mm TRRS to PS 4.4mm TRRRS Balanced
LR Series Custom Cable for 2.5mm (B-Lock)
Wire Braid: Round
Sleeving: White/Silver
Y-Splitter: Viablue Aluminum
Slider: Blue
Apollonian+ Series Custom Cable for Focal (Utopia)
Wire: Silver Plated Copper (Type 6 Litz)
Sleeving: Black
Termination: 4-Pin XLR Balanced
Y-Splitter: PS Black Aluminum
Slider: PS Black Aluminum
Poetic Series Custom Cable for FitEar
Sleeving: Black/Red
Braid: Round
Thanks PlusSound. Really like all your superb cables. Very well-made, and sounding.
Going to get an upgrade soon.
