So, have you ever replaced an entire product because a small component had a failure, and it was too pricey to replace? Or maybe upgraded a product because it just couldn’t do the same as the new ones?
What ever it is, it would be a big help and much appreciated.
I. Audio gear
a. Replaced due to component failure
1. Countless
cables (most of them stock), more on IEMs or in the car, where the problem isn't near the TRS plug
2. Many
beater IEMs (ie most expensive is the Shure e2c)
(Sidelined) Meier Cantate.2. I need to have it fixed but not willing to totally give up on it. Using a Schiit Asgard 3 in the meantime. Can relegate the Schiit to back up or swap them out when I have the Meier working again.
b. Upgraded due to obsolescence/compatibility, or just my own changing needs
1.
Little Dot MkII. I still have the HD600 I bought it for but even if that wasn't bad driving it, it just wasn't as good as my Meier Cantate.2 on it and more importantly, on lower impedance headphones.
2.
SuperPro 707 because when using via USB the analogue output goes from 2V to something like 6.5V.
3. A string of
car stereos, due to changing processor needs or later, when CD changers just can't compete with the iPod or Androids, including just getting a newer car with a modern stereo.
4.
Car processors. Either built into head units or now, one that can work with factory stereos - basically I get all the processing I need from this and then add an amp and change speakers without gutting the stock receiver that isn't a DIN-standard unit anymore on current cars.
5.
Home audio tower speakers and standmount speakers. Worked fine at the condo my parents rented for my brother and I back in college, totally effed when I moved in back home (traffic wasn't as big a problem if your only concern is making it before 9am and going home at 6pm without having to deal with term papers as much) due to acoustics at the old house with concrete outer walls and wood inner walls. And now I'm on Head-Fi.
c. A little bit of both
1.
Marantz CD60. This generation of Marantz CDPs and the equivalent Philips machines are notorious for the constant breaking of the CD tray mechanism on the Philips transport they used. I constantly replaced it, as the components were cheap and easy enough to find on eBay (albeit the shipping cost being the problem). But eventually I realized it wasn't reading some CDs and it wasn't from a misaligned laser, but that it doesn't understand instructions on newer CDs with PC media to move the laser out to get to the normal audio content. Replaced by "iModded" 5.5g 120gb.
2.
iModded 5.5g. Got replaced by a Samsung Galaxy S3 so I only had one device in my pocket when on the go, and works via digital out at home.
3. String of
Android phones, firstly because they'd be slower and T-Mobile either offers new phones cheap then I give the phone to younger cousins or nephews, or even some of my aunts who don't use newer phones (heck I actually also just get some of my phones used from my brother as we only really need one upgrader to kick off a chain reaction). More recently, T-Mobile was buying them back, and my SGS7 Edge was really fckn slow even after factory resets.
4.
SGS9. I didn't really replace it totally ie I'm still using it, I just stopped using it because Android had another update that nixed USB audio output so I replaced it with the Hidizs AP120 as my audio server but now just via its own line out. Need to replace OLED screen, but still works for the following though:
a. A second sim card
b. Streaming Spotify to the Hidisz AP120 (I have my main phone working as remote for the FLAC on the AP120's SD card)
5. An old
Sony HU because its CD changer stopped working
6.
AKG K66. Used to just be an auxiliary with an iPod, but the cable broke and I gave up on speakers at that point, and that's how I ended up with the Sennheiser HD600 in 2010. I still have that headphone but might add a K702 or HE400i/Susvara to it soon.
II. Non-audio or non-audio specific gear: all a little bit of both for most unless otherwise indicated.
1.
Core2 Duo Vaio workstation laptop. Can't find a replacement battery, can't play some lighter games I'd much rather play on a laptop in my room than go run the desktop in a room that really requires running the A/C. Replaced by a cheap 15.6in with an AMD APU.
2.
Acer 15.6in with AMD APU. Can replace battery, but at this point I really needed portability and if I need to, I can run the desktop and then stream light games that don't care about latency to it via Steam (that other room still gets hot, but I'm not in there so as long as the desktop doesn't overheat, no problem).
3.
Lenovo Yoga 11.
The chassis just started crumbling. Repairs will cost as much as a new one...decided to get an HP notebook.
4.
HP notebook. Not totally replaced, but since I replaced the desktop with an octacore, RTX 3060 gaming laptop, I'm working primarily on the latter with the touchscreen HP running some side apps like for when I need to take notes, check something else online so I don't switch windows, etc.
5.
A string of desktop parts and whole PCs. i7-2700 rig had a graphics card update, then eventually my brother just gave me his Skylake rig. That thing in turn was in an older chassis and at some point the non-grommeted cut outs cut the CPU power cable and shorted it. Still kinda works, but won't overclock the CPU anymore and is noticeably slower on the 1% lows on Total War games (I didn't take actual FPS but I was getting way more stutters, ie, how it worked on older quads when not overclocked).
6.
iPad2. Got stolen along with my
Note3 in 2018
. Using a cheaper Samsung tablet, S9, and MotoG 5G now.
