Playback Designs DACS
Mar 13, 2025 at 10:59 PM Post #301 of 340
I'll check it out, does it work with bandcamp and jriver? Also should I turn bitstreaming on with PBD stuff?
Everything goes to CoreAudio so yes it should work system wide
Mar 14, 2025 at 8:27 PM Post #302 of 340
When it's playing DSD should the red letters read "PLINK IN DSD 2X" or should it read 176.4Khz for the same album. IF I turn on DSD bitstreaming I get the first if I turn it off I get 176.4khz.
Mar 18, 2025 at 9:00 AM Post #303 of 340
Looking into the MPD series as a possible next DAC upgrade and wanted to ask fellow PBD owners some questions:
- It's kinda tricky to find a comparisons between the MPD-6 and MPD-8 online. Apart from better sound, what advantages does the MPD-8 have over the 6?
- I'm also confused about the difference between the MPD series and the MPS series. Both have DACs right? So what's the difference?
- Finally, does the MPS-X option just add streaming to the MPD DACs? Without the MPS-X the only digital input is USB correct?
Thanks!
Mar 18, 2025 at 9:06 AM Post #304 of 340
Haven’t heard the MPD6, but love the MPD8.
MPD is the DAC and the MPS is the streamer/player. MPT is the transport. The MPS-8 has a dac in it but it’s not at the level of the MPD.
The description on each of these is pretty accurate. https://verdantaudio.com/collections/playback-designs
Mar 18, 2025 at 9:10 AM Post #305 of 340
Thanks!
PM @F208Frank He moved from the MPD-6 to the MPD-8. He should be able to help you.
Mar 18, 2025 at 10:48 AM Post #306 of 340
I was asking pretty much the same question and had a nice answer from Andreas himself regarding Dac differences between MPS 6 / MPD 6 and between MPS 8 / MPD 8 :
"The DACs for the MPS-6 and MPD-6 are identical. The ones for the MPS-8 and MPD-8 are not. The MPD-8 is double differential whereas the MPS-8 is single differential. The MPD-8 has separate power supplies and separate PCB's for each output channel, whereas the MPS-8 has single power supply and PCB for both channels".
Unfortunately i need a cd player as i'm still not looking to do demat yet so the price range between MPS 6 and 8 is quite something...
Mar 18, 2025 at 11:33 AM Post #307 of 340
There is an MPD-8 / MPT combo up for sale in NL but still a big chunk of change....
Mar 18, 2025 at 2:07 PM Post #309 of 340
Mar 21, 2025 at 7:02 PM Post #311 of 340
All I know is I've never heard sound this good.
€36k including tax.
I paid less new. What site is NL? If used thats too high.
Mar 22, 2025 at 1:41 AM Post #312 of 340
A company in the Netherlands. It's MPD8 &. MPT-8 with stream x2.
Mar 23, 2025 at 7:19 PM Post #313 of 340
Mar 24, 2025 at 3:09 AM Post #314 of 340
