The Mobius is just awesome for gaming.I loved it. Regret I can't find it now. It was kind of decent for gaming too.
Any idea why they keep popping up in the sale forums for almost 50% off? How does it sound wireless with the LDAC codec?The Mobius is just awesome for gaming
Would it be possible for anyone who has owned or auditioned multiple planer headphones to tell me from darkest to brightest......where each of the planar hp models stand? If it's easier you can do this by company, Audeze, Hifiman or any other brands you can think of.
Doesn’t bring all the bass that they can handle but for $99 it is a very good amp and even get the Abyss loud but still lacks the bass it definitely has.
But Mobius has a disadvantage according to Z Reviews that it can't be used with the cable if the battery is dead.Mobius is brilliant - love the 3D, but sound excellent with nothing engaged. Also worth looking at : Brainwavz Alara. Essentially pretty neutral - nice extension in the bass. Very comfortable.
I agree with everything you said/what you’re thinking.While there is a part of me that wants the the LCD classic (bass lover side), I know I will most likely just find it dull after a while, if not immediately. I think for me the only Audeze I will probably like is the LCD X. It is easy to drive and is the most forward sounding.
Now from the online demos I have heard it sound like the Hifiman HP's are a little better in the upper mid range and treble, giving up bass impact and smoothness to the Audezes. I will probably go for either a used Ananda or HEX, both being easier to drive than say an HE500 or 560.
Used Anandas are easier to find than HEX's. What makes me hesitant to get a used Hifiman is their QC as opposed to Audeze's QC, which look like they are built like tanks. Actually, If I can find a used Sundara really cheap around $300 I might get that. The LCD X and Ananda both go for around $700 to $800 used so its just a tossup as to which sound I might prefer. The LCD X is a staple is many studios, so that may help sway me right there.
Excellent review Paul, now I am really interested in these. Do you think these are worth an upgrade over HD650s?Follow up from my earlier post:
Brainwavz Alara - Open Planar headphone : https://www.headphone-earphone.reviews/2019/01/06/brainwavz-alara-planar-open-headphone-review/
This one is something special IMO.
Oh that is a great question.Excellent review Paul, now I am really interested in these. Do you think these are worth an upgrade over HD650s?
Thanks, I am in India and hope that Brainwavz would release Alara in India soon.Oh that is a great question.
The HD650 is an excellent headphone, and now that you can get equivalent (HDXXX) from Massdrop for ~$200, they are incredible value. The HD650 has the better mid-range if you’re looking for smooth and slight colouration. Alara has better speed and transient response, better bass quality, and is more neutral end-to-end.
It’s probably more a side-grade than an upgrade, simply because of the price difference. I do think the fidelity is better with the Alara. Enough that my HD600 will possibly go for sale (hard to let go of a reference set).
Would suggest trying first if you get the chance. If you are in US, I think Mshenay was trying to arrange a review tour.
I would make sure they have a decent return policy because they fit only 2 out of 5 in my house for Christmas all adults and not small heads on the smallest adjustment. They sound very good though and will have my own review of them very soon.Thanks, I am in India and hope that Brainwavz would release Alara in India soon.
