Mhog55
What's the weight on these?Spent the past 30 min with them. Still on my head actually. Don't want to take them off. No HiFiMan has done this for me. I've found my Planar.
If it were to fail, if you're in your 1 year warranty just contact us and we would give a free new replacement headband.Fluctuates a lot. I got mine about a month ago for 199.99 (used) off amazon which was actually brand new in box, but the version with fragile yokes. Even if it breaks and even if they charge me for reinforced its still 100% worth the $275. They're damn good headphones as long as you can drive them. Actually I'm just assuming its the yoke one, it is woodgrain/black though.
Innovating the art of listening.
Stay updated on HiFiMAN at their sponsor profile on Head-Fi.
That would certainly be an incredible deal...! I'm also seeing Price: $595.55
That's why EQs exist! Btw imho, the biggest advantage in the bass of planars is actually the quality of the bass; the detail you can hear in the instruments, for instance; with planar almost be able to the drum body resonate while dynamic would be more like a 'blob'; mushy; blurry sound with no realistic detail. But they likely won't have 'more' bass (as in mid bass bump or just crazy boosted bass à la 990 or others), but they'll likely have better (flatter) bass extension and just better quality bass. You can find a couple of posts arguing here of 400i vs dynamic headphones: https://www.head-fi.org/threads/hif...-and-discussion.698974/page-816#post-13492713
The 4xx is closer to 400s, and from what I remember reading when looking 400i vs 400s was that the 400i was overall better; with a more solid bass. But, 170 for 4xx though, and I think the 400i was around 250 these days? 230 even maybe? I think they'd all be good choices, with 560 best if you can find a good deal. IMHO, the 560 is a smoother headphone than the 400i, which un-EQ'd can sound a tad bit bright/harsh; still similar sound, owning the 400i and hearing 560, sounded to me like more or less a more refined 400i. And yeah I think I remember reading that the Sundara's 500 price of a couple months ago was down to 350 or such, so that could also be a good contender.
And just another 'btw', you mentioned the 770, that's a closed headphone and its bass will also be significantly different than just any open headphone, be it the Senn 598, 6xx, AKG Q701 or 7xx, etc., so if you're not used to 'good' open headphones this would also give you another experience, in my earlier linked post I described Q701 vs 400i, and honestly, un-EQ'd, I'd think most would likely say that the Q701 has 'better' bass than 400i because most people cannot tell good bass from bad bass, and confuse a mid bass hump or boosted bass with better bass; since it often gives the impression of more (bigger) bass, and even more 'solid' ass... I think also there might be something about bass distortion from a dynamic driver adding some 'weight'... Anyway... But yeah, coming from 770 which has a ton of bass, I think you might be a bit disappointed if you expect any such bass quantity or 'weight' from a planar.
770:
400i:
But hey, I think you mentioned like $500, Senn 6xx + AKG 7xx + HFM 4xx total $560.![]()
This is incorrect. Planars have better bass extension than dynamics but more mid bass. It also depends on the planars there is some crap planars and crap dynamics.IMO the only advantage dynamic headphones have over planar magnetic one's is the bass and treble is more extended. Dynamic headphones have more presence in the 15-25Hz region and also 15-20KHz region. Otherwise, I would say that planar is better. I recently bought the Fostex TH500RP and it is the second most natural sounding headphone I have ever heard (second only to the Sony MDR7510). However, the only true advantage the MDR7510 has over the TH500RP is deeper bass and more detailed, clearer in the 15-20Khz frequencies.
I'm sorry to disagree, but no - planars do not have better bass extension. Do they have flatter/linear bass? Yes! but do they have lower bass? no! There is no way that a planar magnetic could achieve the level of sub-bass that a dynamic headphone can produce. This is sign of the limitations of the structure of a planar magnetic driver. It is uniform and flat, where as a dynamic driver is 3 dimensional and round, thus capable of reaching the lowest notes.This is incorrect. Planars have better bass extension than dynamics but more mid bass. It also depends on the planars there is some crap planars and crap dynamics.
Can you hear 10Hz? Fair enough. I personally prefer dynamics for bass but I don't hate planars. Have you heard any of the Fostex TH-X00 or older Denon (the AH-D2000/5000/7000) headphones? I've owned the AH-D2000, AH-D5000 and TH-X00 Purpleheart, I remember doing some tests on them using software and the Denon AH-D5000 registered the lowest bass (14Hz). The thing about the AH-D5000 is that not only is it very flat/linear but also has that subwoofer BOOM that planars can't even hope to achieve.
Personally I never paid much attention to graphs, I prefer to use my ears. The LCD2 does show a flatter, more extended response, but the D5000 shows a louder response. So the lower frequencies in the D5000 should stand out more, whilst maintaining a relatively flat/linear response.Compared to similar-tier planar, the D5000 is not that linear. It definitely has a hump and roll-off compared to, for example, the LCD-2. Worse, it has tons of distortion in the bass. That's sort of what I was getting at when I said planar bass does better at controlled and accurate sound. Subwoofer boom or distorted flab?
https://www.innerfidelity.com/images/DenonAHD5000B2012.pdf
https://www.innerfidelity.com/images/AudezeLCD2Classic.pdf
right.Wrong
Not very heavy, the height at the smallest setting on the headband is the biggest issue for people, only slightly/barely for me.Excellent. Is it just the bass that's making you feel warm and fuzzy?
right.
