Caipirina
- May 25, 2015
If they cost the same price, what would you choose between Pioneer SE-A1000 and Sennheiser HD650 ???
Very clear answer: Both
YES!....errr, NO!, Maybe?...DependsWell is the HD650 worth the price difference?
K I just ripped off the felt covers to find another foam cover underneath lol. Left then foams on.
Now It seems that slight roll off in the treble has opened up immensely, might even be too bright/harsh now so i have to find a thinner substitute
I did that recently and it was too harsh and fatiguing, too many sharp peaks throughout the audio band. I tried adding more dynamat to the backside of the baffle than I already had and that solved the issue entirely. I think Pioneer really did do a good job with the drivers after all, but the housing needs to be dampened against vibration or made of that magnesium stuff like with ATH-AD2000, AD900, etc.
Alternatively, they should have used wood. The cloth covers tame the sound, sure, but kill fidelity as a result.
These modifications are a big departure from the stock sound, however. The sound will become much more clear and analytical as well as a bit thinner, more akin to K601. The overall sound quality should be right on HD558's heels, I estimate from memory. I sold off HD558 before even acquiring the Pioneer, so I cannot compare.
Also, the little "joints" at the ends of the headband rods are hollow, and when I tried loading them with Dynamat, the soundstage became noticeably larger and bass became more controlled. You can see those "joints/cups" sticking out in this tekerugburn pic. Removing the first layer of cloth plus dynamat loading results in a bigger, more 3D soundstage, very nice.
Thanks nice to know. Were you able to get a tight fit?
I mean the headphones to be a bit tighter on ears.
