Interesting idea. Is that common?
No, not in England. I’ve never heard of such a thing, amateur orchestras maybe but the professional ones, nope, there’s just not the money to rehearse everyday for weeks. Typically it would be a couple of rehearsal sessions, probably on the same day or spread over a couple of days, then a dress rehearsal on the concert day (that’s usually more of just a run through) and that’s your lot. One rehearsal, then the dress rehearsal and gig is entirely common/usual. Really important gigs with more challenging pieces, such as big premiers of contemporary works, might get 3 or 4 rehearsal sessions possibly 1 or 2 more under truly exceptional circumstances, baring in mind two rehearsal sessions a day or a rehearsal session and gig but I’ve never heard of rehearsing everyday for weeks, I don’t know how that would even be funded. British orchestras, particularly the London orchestras, are well known for their sight reading and short rehearsal skills because of the way they’ve been funded historically, that’s one of the reasons they’re attractive for film score work. “Everyday for weeks” sounds to me like a bit of creative marketing!
If they recorded a lot of different pieces then the same mic setup might be appropriate, in which case using 100 or so would make more sense, although for studio work that would usually not be the optimal way of doing it. They do the BBC Proms with about 130 mics but that’s because they have to set them up before the festival starts and then cover pretty much every sort of classical ensemble imaginable for the next 2 or 3 months with that same setup, which they’ve developed of a period of about 60 years!
Out of curiosity, is there a generally accepted number for "enough voices"?
Not sure what you mean by “voices”, do you mean musicians, mic channels or audio channels? The number of musicians can literally be up to 1,000 (Mahler’s 8th Symphony) and even in the 1830’s, Berlioz’s Requiem was scored for about 450. Orchestra sizes typically top out around 100-125 (Sacre du Pretemps and the Alpine Symphony for example). The number of mic channels will often start to be self defeating from around 50 upwards but there’s no hard rules, it’s dictated by what you’re recording, where you’re recording it and what amount of flexibility you might need when mixing. Film score work commonly uses the most mics but the problems can be reduced with (transparent) screens which provide a little more isolation between the mics. The number of audio channels can be over 400 but that’s really only film scores, where it’s not uncommon to have an entire symphony orchestra plus a MIDI (sample) orchestra mixed together to create a sort of super orchestra (Hans Zimmer pioneered that trick), hence the ridiculous number of audio channels. Film sound is where the channel counts can get really huge, up to about 1,500 or so in some instances (including the music). Typically there would be 3 mix (“re-recording”) engineers working together/simultaneously on a mix of that size.
G
