kin0kin
- Jan 4, 2005
you are overly worried. As long as the rail splitter is working, you can hook the tread to it and power it on. you don't need 24v precisely.
as for replacing vset for a resistor, you have already been told in post #14. you can replace R2 and jumper the two points(2 and 3, or 1 and 3), or just simply get another resistor of the value (1685 - R2 = Resistor you need) and solder it on the two points (2 and 3, or 1 and 3....it is the same anyway) and you will get close to 24V output.
