kin0kin
- Jan 4, 2005
load or not, most likely you will be getting 25.x V as measured from the thread. the only time an unregulated wall wart would output at it's rated voltage is when the current draw is near the maximum rated ampere on the wallwart. My 24v wallwart, regulated with lm317 with similar circuit as the tread measured 18.36V from the regulator output, and again measured 18.36V when loaded.
btw, caps generally could take voltage surge for a short period of time(I can't recall how many secs), so if you feed a 25V cap 25.x V for a few sec it should be fine, you probably would have enough time to determine if the loaded voltage will drop below 25V which I highly doubt, before it explodes.
![biggrin.gif](http://www.head-fi.org/forums/images/smilies/http://hfimage.head-fi.org/smilies/biggrin.gif)
