Phillips SHP9600
Oct 16, 2020 at 9:14 PM Post #16 of 43
I got the two over the past couple of weeks, and bass is definitely more present in the SHP9600. To me SHP9600 sounded like it had a bump in the mid/upper bass region compared to the X2HR. The SHP9600 has a more pronounced V-shaped sound then X2HR, which sounded more neutral in comparison. Overall I slightly preferred the X2HR's sound, but I had to return it because I found it too uncomfortable for my big head.
SHP's look to have a stronger upper bass hump, with a steeper slope down from ~100hz, making lower bass particularly weak. For my listening tastes, think the SHP will stay on my list of good cans that don't suit my sound sig.
Oct 16, 2020 at 9:52 PM Post #17 of 43
Yeah between the two, the X2HR had better bass extension and the SHP9600's upper bass bump caused some muddiness in some songs. It's definitely has it faults, but I still find it pretty enjoyable, specially if you can get it for around $100.
Jun 27, 2021 at 8:22 PM Post #21 of 43
Okay sound. Cheap open full size with comfy fabric mesh earpads. On sale, and came bundled with aftermarket mic.
Jun 27, 2021 at 10:05 PM Post #22 of 43
Tearing down for mods.
Jun 29, 2021 at 3:37 AM Post #24 of 43
Jun 29, 2021 at 1:23 PM Post #25 of 43
Taped front baffle to add some warmth to sound, but 2kHz dip was exacerbated.
How to remove driver? Glued in. Prying at edges is not working because I am worried I may break plastic baffle. I could try popping out from front side but that would destroy driver. Hmmm
Jun 29, 2021 at 1:41 PM Post #26 of 43
350degrees for 5min is too much. Driver came out easy but also warped baffle and unglued silk screens. Maybe a hair dryer next time. Or just pop drivers out from front side since Id really no plan for reusing them anyway.
Jun 29, 2021 at 2:03 PM Post #27 of 43
Much easier to pop out from front. Ruined old driver though.
Ill ask Philips about replacement bafflr or just order another headphone.
Jul 3, 2021 at 11:04 AM Post #29 of 43
Peerless driver on right. Accidentally brushed my finger against and lightly dented. Wonder how much effect that has on sound. No worries, $10 piece.
Jul 3, 2021 at 1:56 PM Post #30 of 43
Works. My first soldering was not good. Sealed in place with damplifier pro.
