Ggroch
- Apr 2, 2014
The stock cale it comes with is not that great and there is some hiss/static going on when using stock. Once you upgrade that cable, most if not all that hissing will be reduced and make it sound a bit better.
My experience is not the same as yours. Your have far more posts than I, and I do not want to be rude, but the stock cable sounds fine on my set, and I am certain it is not hissing.
I have difficulty seeing how a cable (which is just a piece of wire) can hiss...unless it is somehow defective in making or isolating contacts.
I can see how a poorly designed cable with a high impedance might effect the sound, smearing detail slightly, but it still would not hiss.
The cable is a standard 3 contact plug, so if your source is not designed for standard 3 contact 3.5mm plugs (if it has mike or switching contacts), it is possible that things are not lining up right would cause issues.
It is possible that a cable with a built in microphone may sound different because it may have circuitry designed to reduce noise to the listener...but that would not be cable hiss, it would be removing hiss from the actual source.
I have used other 3 conductor cables on the SHP9500 to get a shorter length and they sound exactly the same to me. I am certain if the stock cables were hissing you would see it in the majority of SHP9500 reviews.
Come to think of it, I have never heard "cable hiss" described in any professional review of any headphone.
