Vatnos
- Oct 14, 2016
I find the bass of the SHP9500 quite reasonable. The treble is just overly accentuated. These are bright headphones. Warm amps tend to do good things for them though.
boosheetwhat bass? they have no such thing.
@Mikis76, you're correct, those would be the ones I'm talking about. They feel just like the pads on the DT1990 Pro, and if you're okay with those, then you'll be okay with the Shure 1840 pads. One additional step I took was to buy some SHP9500 adapter pads from modhouseaudio.com. That helped to switch out pads easily and keep the original pads intact. Hope the Shures work out for you.
Did you buy the adaptor rings or just stretch the pads over the ear cups?
Thanks for the response. I think most people who change the pads are stretchers.Hello Gargani....It seems that I´m a "stretcher"....it took few minutes to get them on but was quite easy after you get it going. So no adapters in this case.
replacement pads will just go around the outer edge of the headphones, no need for adaptersI recently bought some SHP9500s and I really like them a lot. Not just for their sound but because the light clamping forces combined with a good fit just makes me forget I even have headphones on. I pulled the cups out of the band as far as they will go, then wrapped a layer of electrical tape around the metal piece, then closed them back to the adjustment I prefer (4) and this keeps them at that setting, because the only flaw I had with these headphones was that the cups would keep pulling out of the band and I had to constantly re-adjust. Solved now.
However, I have been considering changing the pads on them. I kind of like the material the pads are made out of, but they feel rather hot after long periods of use. I was wondering if velour pads would feel any better and if it's really worth it to go that route. I would like to preserve the originals just in case. I guess I should get some ring adapters so I can preserve them.
I don't want to sound rude, but are you not actually reading this thread? You don't need adapter rings, you don't need to destroy the original pads...you pop off the old pads, you wrap the new pads around the outer edge of the headphones...look at the picture I posted. Those are generic 'HM5' style pads, you just stretch them over the outer edge of the headphones.Will an adapter ring replace the original ring? Or do you still have to destroy your stock pads?
if you can just pop off the old pads with the plastic that comes with them and stretch HM5s over, then i'll order a set of velour pads and give it a try
