What do you mean by "Ss?" Sibilance? Sibilance generally falls between 2 to 10khz but varies depending on the particular voice or whether it's cymbals or snare-brushes or something.
https://en.wikipedia.org/wiki/De-essing#De-essing_without_automation_or_with_manual_equalization
https://theproaudiofiles.com/vocal-sibilance/
As you can see by reading those articles, "de-essing" is a complex process that isn't the same across all systems but more importantly, isn't the same on all material/songs.
As for changes that a higher output-impedance may cause: This graph from DIY Audio Heaven shows the frequency-response of the X2HR from a very low (0.2ohm) output-impedance shown in green vs a very high (120ohm) one shown in green:
As you can see, a higher output-impedance will increase the mild bass-hump on these headphones to a much less mild hump, bloating up the bass (however thankfully nowhere close to the bass/mids boundary). However, the graph shown involves the shift from a 0.2ohm impedance to an insanely high 120ohm impedance; a 10ohm impedance like you're talking about will probably bloat up the bass a BIT, but not nearly as much as a 120ohm impedance does. That being said, it's recommended to always use an amp with impedance 1/8th or lower than that of the headphones. For the 32ohm X2HR, that would mean 4ohms or less is recommended. At 10ohms, the bass-bloat shouldn't be too much, but
the bigger issue is distortion. A (too) high enough output impedance will ALMOST ALWAYS increase distortion, which obviously isn't a good thing. Unfortunately, I can't find any graphs of how the distortion-plot of the X2HR changes with impedance, but I can almost guarantee you that it probably isn't very pretty. I personally wouldn't recommend using an amp with 10ohm output for headphones with anything less than 80ohm impedance.
However, keep in mind how I said "almost always" above. These things vary unpredictably, unfortunately. It's ENTIRELY POSSIBLE that the X2HR's don't distort with overly-high impedances from amps, as not all headphones do! It'd be hard to say without A/B testing or measurements.
